the flying hodor Posted April 23, 2015 Share Posted April 23, 2015 hi again guysso at the moment i am on dci have a basic twin oval set up with a few sidings i use a two controllers for this set up the points that connect the ovals are connected with insulated fishplates to stop any shorts as i said before in another post i am going to go dcc do i need remove the insulated fishplates with normal onesto run dcc cheers one again daveps i know i have to use some clips on the points Link to comment Share on other sites More sharing options...
Chrissaf Posted April 23, 2015 Share Posted April 23, 2015 Basically for DCC all the track needs to be live in a single power circuit. That is the function of the point clips, so you have two options. Option 1, change the insulated point joiners with normal metal ones and fit point clips. Or option 2, do away with the need for changing joiners to metal AND fitting point clips**. Install a few droppers (small wires soldered to the outside of the track at strategic locations) and connect them all together under the baseboard back to your DCC controller output. Strategic locations would be on each of the sidings and each side of the points on the two main ovals. That way there would be no need to lift track to change joiners. Your layout would then have multiple power connecting locations, spreading the power load and minimising fault libilities. If you go for option 2, make sure ALL the droppers are the same way round else you will create a short..Note ** there are other posts on here that suggest that point clips can fail over a period of time and cause electrical overheating with the result that the plastic in the points melt. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 23, 2015 Share Posted April 23, 2015 While what Chris says is best practice, many users on here have run large layouts without doing this and without melting their points over extended periods. If I were you, I'd start just by removing the IRJs and putting back the metal ones, and fitting DCC point clips and see how you go. I wouldn't even think about the dropper approach to make a DCC bus until you have decided on a layout you want to develop and not change for some time. And no question is silly, except for the one you don't ask. Link to comment Share on other sites More sharing options...
