DCayón Posted May 5, 2015 Author Share Posted May 5, 2015 Hi Fishy, DC doesn't have the Select. He has the much more limited EZ Command. Very limited as to what you can do with it.Peter But in my trains club they have one that is very similar. Link to comment Share on other sites More sharing options...
DCayón Posted May 5, 2015 Author Share Posted May 5, 2015 I will try to fix it with the help you have provided this Friday Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 5, 2015 Share Posted May 5, 2015 Sorry, yes, my mistake. Surely the EZ Command can adjust acceleration and deceleration? If it can, then what I have suggested still applies. If it can't, there's basically nothing you can do to change anything. If if you can get hold of a more capable controller at your club, you need one that can read and write all CVs, so more like an Elite than a Select. That way, you will not only be able to adjust accel and decel in CVs 3 and 4, but also Start Delay in CV201, and also check which speed algorithm works best for you in CV150. Check out the leaflet as to exactly what these mean, they are well covered in it. Link to comment Share on other sites More sharing options...
DCayón Posted May 6, 2015 Author Share Posted May 6, 2015 Sorry, yes, my mistake. Surely the EZ Command can adjust acceleration and deceleration? If it can, then what I have suggested still applies. If it can't, there's basically nothing you can do to change anything. If if you can get hold of a more capable controller at your club, you need one that can read and write all CVs, so more like an Elite than a Select. That way, you will not only be able to adjust accel and decel in CVs 3 and 4, but also Start Delay in CV201, and also check which speed algorithm works best for you in CV150. Check out the leaflet as to exactly what these mean, they are well covered in it. This Friday I will do that.Thanks Link to comment Share on other sites More sharing options...
