spitfire001 Posted May 7, 2015 Share Posted May 7, 2015 hello,i have a hornby r2812 dcc ready with a problem the two pick up wires from the front bogie have come off the PCB x005r1 please could someone tell me where they go back too ft fw,chg,trk2 etc etc many thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted May 7, 2015 Share Posted May 7, 2015 What does [ x005r1 & ft fw,chg,trk2] mean? Link to comment Share on other sites More sharing options...
96RAF Posted May 7, 2015 Share Posted May 7, 2015 Those are probably chalk marks on the pcb Chris - the board and version number - x005r1 and the individual tag connection marks - the others.Sptifire - logically the dummy bogie pickup wires would attach to the pcb at marks trk1 & trk2 or trkl & trkr, or similar, etc. Generally the red wire is left and the black wire is right, but some bogies are both wired black so you have to check with a meter which side they are from.The connections are very basic with the wire being pushed onto the tag and the little rubber sleeve pushed on to hold it there - little wonder they fall off.The other connections are for the motor (usually the pair at board centre) and power and switching for any directional lights).If you trace the copper lines on the board you can usually work out what is for what. Link to comment Share on other sites More sharing options...
