Wayne2467 Posted May 10, 2015 Share Posted May 10, 2015 Arrived today- ran ok at first then made a clicking sound before derailing due to the wheel couplings ( not sure if that's what they are called) falling to bits. Not having to much luck with locomotives Link to comment Share on other sites More sharing options...
Graskie Posted May 10, 2015 Share Posted May 10, 2015 Unless you did someting like pick it up and hold it by means of the valve and motion gear, which could have distorted things, it sounds like an immediate return job for a replacement. Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 10, 2015 Author Share Posted May 10, 2015 Unless you did someting like pick it up and hold it by means of the valve and motion gear, which could have distorted things, it sounds like an immediate return job for a replacement. No nothing like that just picked it up from the body as usual. When I heard the clicking noise had a quick look to see if there was something there that shouldn't be Underneath. But Amazon are great on returns Link to comment Share on other sites More sharing options...
96RAF Posted May 10, 2015 Share Posted May 10, 2015 Its always wise to give a new model the evil eye after deboxing it looking for obvious faults and also any more devious problems, especially the complex and extremely delicate valve gear and connecting rods on steamers.Maybe you could have picked up the fault when you were lubricating it according to the maintenance sheet provided. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 10, 2015 Share Posted May 10, 2015 Don't think you need to lubricate a brand new loco RAF, unless it's been in its box for months before being purchased. Link to comment Share on other sites More sharing options...
poliss Posted May 10, 2015 Share Posted May 10, 2015 Sounds like the motion was bent or not fitted properly. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 10, 2015 Share Posted May 10, 2015 Perhaps the motion was distorted or a screw was loose, no not mine. Edit: sorry poliss didn't spot your entry above. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 10, 2015 Share Posted May 10, 2015 Definitely a return under warranty job. Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 17, 2015 Author Share Posted May 17, 2015 Just ordered another of these coming tomorrow. Hopefully have more luck this time Link to comment Share on other sites More sharing options...
poliss Posted May 17, 2015 Share Posted May 17, 2015 Is this a replacement or a new order? Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 17, 2015 Author Share Posted May 17, 2015 Is this a replacement or a new order? A new order Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 17, 2015 Share Posted May 17, 2015 So you'll have 2 after the faulty one is replaced under warranty? Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 17, 2015 Author Share Posted May 17, 2015 So you'll have 2 after the faulty one is replaced under warranty? No because I sent the first one back for a refund. In the meantime I bought an elite controller and now trying the Gadwell again. Got my eye on the cock of the North for end of july too. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 17, 2015 Share Posted May 17, 2015 Ah, now I get it. Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 18, 2015 Author Share Posted May 18, 2015 Just to say the new one is running like a dream touch wood Link to comment Share on other sites More sharing options...
