RDS Posted May 14, 2015 Share Posted May 14, 2015 An unboxed Elite went for just under £113 incl. postage tonight. Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 15, 2015 Author Share Posted May 15, 2015 It's arrived without instructions so iam looking at the ones online. Trying to programme three locos to addressees without success. at the point where the light should flash five times to assign the address, I get about ten flashes and a message stating write cv value? If anyone can advise would be good. Link to comment Share on other sites More sharing options...
Woody52 Posted May 16, 2015 Share Posted May 16, 2015 Hi Wayne, Just checking that you have set up a Programing Track and that you are using it to try and reprogram your decoders.Peter. Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 16, 2015 Author Share Posted May 16, 2015 Hi Wayne, Just checking that you have set up a Programing Track and that you are using it to try and reprogram your decoders.Peter. Yes I did thanks. Managed to sort it eventually and all three locos running ok now Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 17, 2015 Author Share Posted May 17, 2015 Can anyone tell me what kind of connector goes in the elite to hook up with a laptop? I can see that it is not a standard usb. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 17, 2015 Share Posted May 17, 2015 Wayne,It is most certainly a standard USB connector, albeit quite an old style mainly still seen these days on printers and some scanners. It is a USB Type B Male connector at the Elite end and a USB Type A Male connector at the PC end. It is a USB 2.0 cable backward compatible with USB 1.1 specifications..This link is just a typical example (clicking link opens in a new page) Link to comment Share on other sites More sharing options...
Wayne2467 Posted May 17, 2015 Author Share Posted May 17, 2015 Wayne,It is most certainly a standard USB connector, albeit quite an old style mainly still seen these days on printers and some scanners. It is a USB Type B Male connector at the Elite end and a USB Type A Male connector at the PC end. It is a USB 2.0 cable backward compatible with USB 1.1 specifications..This link is just a typical example (clicking link opens in a new page) Thanks Link to comment Share on other sites More sharing options...
Telo Posted September 2, 2015 Share Posted September 2, 2015 Does anyone know if you can set up routes using the Elite, i.e operating several points at once? Link to comment Share on other sites More sharing options...
ModelerXYZ Posted September 2, 2015 Share Posted September 2, 2015 Don't know if you can. I know you can using RM through the elite. I always used it through the elite if i used it at all... How else could I hijack trains when I wanted to? Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 2, 2015 Share Posted September 2, 2015 No you can't. Only simple "at the time" operations of single points or locos or accessories, no serially planned events or programs. Link to comment Share on other sites More sharing options...
