Yelrow Posted May 23, 2015 Share Posted May 23, 2015 Hi, this loco came with Majestic set, and has been ok up to now. It now refuses to move, no sound from motor. Before i go any further, perhaps the Brains Trust can offer suggestions, as how to proceed. thanks, john. Loco 60154 Link to comment Share on other sites More sharing options...
96RAF Posted May 23, 2015 Share Posted May 23, 2015 Check it hasn't reverted to address 3 John.If the decoder is set to allow DCC try a PP3 9v battery directly on the wheels to check motor is OK.Also check no fluff in the wheel pickups.If it was ok before then I suspect a wire has come off indoors. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 23, 2015 Share Posted May 23, 2015 Think you mean to allow DC RAF. Link to comment Share on other sites More sharing options...
96RAF Posted May 23, 2015 Share Posted May 23, 2015 Yes - slip of the old typing sausages WTD. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 24, 2015 Share Posted May 24, 2015 Working again john? Link to comment Share on other sites More sharing options...
cas_ir Posted May 24, 2015 Share Posted May 24, 2015 Hi I to have the same the majestic set, and had problems with the Bon Accord, I found that the track pickups were not making good contact with the back of the wheel set all the time ( the wheels have a small lateral movement which the pickups did not track). I disassembled the unit and cleaned and adjusted the pickups (bent them slightly) so they made contact all of the time. Link to comment Share on other sites More sharing options...
Yelrow Posted May 24, 2015 Author Share Posted May 24, 2015 Cas ir, many thanks, will look at. Raf, 96. Need to wire up prog track, again, then can check out. Just changed circuit, to encorporate, all layouts together. Now like a wedding cake, lower tier, DC, first tier, DCC, then 3 rail tier, tt tier, finally N gauge. Means i can operate from one place, and run up to 21 tracks, happy days. john Link to comment Share on other sites More sharing options...
96RAF Posted May 24, 2015 Share Posted May 24, 2015 With a quad decker keyboard like that John and 21 tracks you should have been a church organ player.No need to set up the prog track again - just try it on DC and see if it works - if not then go to plan B to check the CV.Sounds as if it could well be the well known wheel pickup problem though. Link to comment Share on other sites More sharing options...
Yelrow Posted May 25, 2015 Author Share Posted May 25, 2015 RAF 96, greetings, all back to normal now. CV had changed from 012, to 02, interesting, and i cleaned up wheels etc. I have come across locos reverting to 03, before, but not 02, and it is my oldest DCC loco. curious. john Link to comment Share on other sites More sharing options...
96RAF Posted May 25, 2015 Share Posted May 25, 2015 Very odd John but good that you are back to square 1 again. Link to comment Share on other sites More sharing options...
