wuuggy Posted May 24, 2015 Share Posted May 24, 2015 Hi, I seem to be having a problem with the loco speed when controlling it through Railmaster.If I run the loco direct from the Elite it works fine and travels at the correct maximum speed, however when controlled through Railmaster it crawls along, even if I set the speed to maximum.I am baffled as it continued to do this even after replacing the decoderAny suggestions would be welcome, perhaps I need to change a CV value Link to comment Share on other sites More sharing options...
RobinJ Posted May 24, 2015 Share Posted May 24, 2015 Railmaster by default is set to run locomotives at their scale speed, this can be disabled in the programs options menu if you wish. Link to comment Share on other sites More sharing options...
96RAF Posted May 24, 2015 Share Posted May 24, 2015 In the loco setup screen each loco (identified) is defaulted to Hornby's database settings for cruise and shunt speeds. You can if desired override these values and input your own speed settings. e.g. On my short end to end a cruise of 90mph for a Pacific loco is inappropriate so I set mine to 50mph and the shunt to 10mph. Link to comment Share on other sites More sharing options...
wuuggy Posted May 25, 2015 Author Share Posted May 25, 2015 In the loco setup screen each loco (identified) is defaulted to Hornby's database settings for cruise and shunt speeds. You can if desired override these values and input your own speed settings. e.g. On my short end to end a cruise of 90mph for a Pacific loco is inappropriate so I set mine to 50mph and the shunt to 10mph.Thank you for your replies I will look at that today Link to comment Share on other sites More sharing options...
