RB51 Posted June 1, 2015 Share Posted June 1, 2015 Sorry if this information is somewhere in here already, but I am unable to find it. My track plan has started to come up at 100% on launch of RM. Up until today it started at 100% but when all points and signals were set it dropped to 75% (which is what I wanted). I can't remember how I did that now. I thought I could save it at 75% in designer mode and that would be how it fires up, but no. What do I need to do chaps? R- Link to comment Share on other sites More sharing options...
Graskie Posted June 1, 2015 Share Posted June 1, 2015 Mine boots up at 100% but, after a short wait, changes to my reduced saved setting automatically. I think they all do that, don't they? Link to comment Share on other sites More sharing options...
RB51 Posted June 1, 2015 Author Share Posted June 1, 2015 I think they do (should) Graskie - did you just save the 75% setting in the design window - or something else? R- Link to comment Share on other sites More sharing options...
RB51 Posted June 1, 2015 Author Share Posted June 1, 2015 And ...... I now have "bow ties" all over the place and the blue point indicators are mis-aligned. R-/media/tinymce_upload/dbb750968ec77581da971690af567d93.gif Link to comment Share on other sites More sharing options...
Graskie Posted June 1, 2015 Share Posted June 1, 2015 I thought you might ask me that, Roger. I'll just go and check. Link to comment Share on other sites More sharing options...
Graskie Posted June 1, 2015 Share Posted June 1, 2015 50%, Roger. Link to comment Share on other sites More sharing options...
St1ngr4y Posted June 1, 2015 Share Posted June 1, 2015 There is no connection between the zoom level used in the Design window and that in the main window. Railmaster remembers the zoom level in use in the main window when it closes down, then it restores that level when it restarts after setting points and signals.Ray Link to comment Share on other sites More sharing options...
RB51 Posted June 1, 2015 Author Share Posted June 1, 2015 Thanks Ray - how do I get the main screen to 75% then please? R- Link to comment Share on other sites More sharing options...
RB51 Posted June 1, 2015 Author Share Posted June 1, 2015 OK - never mind. Elsewhere in this thread I posted a picture of my track plan - showing the mis-aligned blue point direction indicators and lots of "bow ties". What I didn't realise was that there was a drop down menu in the top left hand corner that sets the track plan size on the screen (it was hidden behind the mouse part of the mouse -v- touch screen icon) that does what I need. This corrupt display stayed like it despite closing down and launching RM several times, but has now sorted itself out. Time for a glass I think. R- Link to comment Share on other sites More sharing options...
96RAF Posted June 2, 2015 Share Posted June 2, 2015 Rog - very odd that those bow-tie artifacts were persistent after shutdown/restart(s) of RM.They are just remnants seen in many CAD type applications because the screen hasn't yet fully redrawn. Although they don't always appear a restart would redraw the screen.A pity there isn't a redraw button in RM to refresh the screen after making alts to preclude the need for the restart. Link to comment Share on other sites More sharing options...
RB51 Posted June 2, 2015 Author Share Posted June 2, 2015 Thanks for that RAF96. Although it doesn't look great the layout still works correctly. I think the idea of a "refresh" option within the operating window is a good idea. Is that in "desirable features" do you know? That is now such a long thread I have lost track. R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted June 2, 2015 Share Posted June 2, 2015 showing the mis-aligned blue point direction indicators I reported this as a fault many moons ago, but as far as I remember, it wasn't fixed. I got it if I started RM then switched a point or two, then changed the zoom level. At that time, I had the "set points at start up" switched off. Since setting this on, I haven't experienced it.Here is a link to the thread I raised at the time:-https://www.hornby.com/uk-en/forum/blue-lines-corrupting-layout-display/Ray Link to comment Share on other sites More sharing options...
RB51 Posted June 2, 2015 Author Share Posted June 2, 2015 Thanks Ray - I have "set points at start up" switched on. I think this is a screen refresh/re-draw issue that just took a bit more "refreshing" than previously. Fired up this morning and blue lines are correctly aligned and the bow ties have gone. R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted June 2, 2015 Share Posted June 2, 2015 Thanks Ray - I have "set points at start up" switched on. I think this is a screen refresh/re-draw issue that just took a bit more "refreshing" than previously. Fired up this morning and blue lines are correctly aligned and the bow ties have gone. R- Now that I've seen the picture of your screen, the mis-alignment of the point indicators isn't by as much as I was having. In my case, after switching from 100% to 50% zoom, then switching a point, the straight portion of the blue indicator was being displayed using the x,y co-ordinates for 100% i.e. it was twice as far from the top-left corner as it should have been.But I'm glad it's working ok for you now.Ray Link to comment Share on other sites More sharing options...
