johnbet Posted June 11, 2015 Share Posted June 11, 2015 Got my new Flying Scotsman and am a little concerned that at slow start off speed it is jerky. Is anyone esle experiencing this and is there a solution?Also some of the sounds only appear to function when the main sound is switched on as opposed to them being stated to all operate even when the main sound is not switched on.Otherwise a nice model and good value. Link to comment Share on other sites More sharing options...
Icurus Posted June 11, 2015 Share Posted June 11, 2015 HiIf this is a brand new out of thebox loco, have you run it in to allow the parts to bed in? At least 15 mins at half speed in both directions is a good start :) Link to comment Share on other sites More sharing options...
johnbet Posted June 11, 2015 Author Share Posted June 11, 2015 Ok will give that a try and see if any improvement. Other models obtained in the last couple of years haven't had the same issue though. Link to comment Share on other sites More sharing options...
Icurus Posted June 11, 2015 Share Posted June 11, 2015 Most new models will run 100% out of the box, but a few need to be run in. :) Link to comment Share on other sites More sharing options...
poliss Posted June 11, 2015 Share Posted June 11, 2015 Try cleaning the track. Link to comment Share on other sites More sharing options...
ron_armes Posted June 17, 2015 Share Posted June 17, 2015 I have the same problem with the jerky start that I haven't had on previous models. I will try the running in to see if it helps. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 17, 2015 Share Posted June 17, 2015 Try using the other running algorithm which some have found useful. Swap CV150 from 0 to 1 to adjust it as described in the leaflet. Unless you are using Select of course. Link to comment Share on other sites More sharing options...
gasway Posted June 18, 2015 Share Posted June 18, 2015 Just received my new tts sound Scotsman today.first run out of the box,and very jerky when moving off.There is a slight clunking noise as well.Very disappointed to have this issue. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 18, 2015 Share Posted June 18, 2015 First run it in for 15-30 minutes each way at medium speed then, if still a problem, try the other motor algorithm as per my post above. Let us know how they go, both of you. Link to comment Share on other sites More sharing options...
johnbet Posted June 22, 2015 Author Share Posted June 22, 2015 Thanks Will give this a whirl and report back. Link to comment Share on other sites More sharing options...
WilliamDavid Posted July 12, 2015 Share Posted July 12, 2015 Mine is rather jerky when moving off. Did the recommendations above work? Link to comment Share on other sites More sharing options...
johnbet Posted July 13, 2015 Author Share Posted July 13, 2015 Have run mine more now and it does seem to be improving - no cv changes made. Link to comment Share on other sites More sharing options...
oliver_chapman Posted July 18, 2015 Share Posted July 18, 2015 My TTS Scotsman is having the same problem with jerky slow speed and is very poor runner with the sound cuting out at slow speed .also has anyone noticed the name plate says flyinc scotsman not fiying scotsman ? Will try the cv change later to see if that helps Link to comment Share on other sites More sharing options...
olly Posted July 18, 2015 Share Posted July 18, 2015 My TTS Scotsman is having the same problem with jerky slow speed and is very poor runner with the sound cuting out at slow speed .also has anyone noticed the name plate says flyinc scotsman not fiying scotsman ? Will try the cv change later to see if that helps I seem to have posted this with a different hornby account for some reason Link to comment Share on other sites More sharing options...
olly Posted July 18, 2015 Share Posted July 18, 2015 Just an update about my TTS scontsman I ran it for over an hour and it's still not a very good runner at all .the sound stops and restarts when running .I have reset the decoder and oiled the loco I also checked the decoder was in the 8 socket correct .looking like a call to hornby on Monday Link to comment Share on other sites More sharing options...
Meatloaf1 Posted July 20, 2015 Share Posted July 20, 2015 Hi - I've also got the same 'jerky start' problem with my new tts Flying Scotsman, even after a fair amount of running in. I returned it to the model shop (Bournemouth Models - great shop, very good service) and whilst they had it for a few days and looked at the decoder, ran it on a clean track, etc.... They've admitted defeat and have returned her to Hornby. Hopefully they can sort this problem out, but good to know (sort of!) that's it's not just me. Link to comment Share on other sites More sharing options...
Fozzy Bear Posted July 21, 2015 Share Posted July 21, 2015 I have just purchasd the Scotsman and have the jerky start problem though it is very minor and only occurs when starting off at shunt speed and in the forward direction. Reverse is fine and when I give her the berries, it is smooth. Sound is fine. The cruise speed seems a bit slow so does anyone know what address number CV to tweak? Link to comment Share on other sites More sharing options...
TED 1 Posted July 27, 2015 Share Posted July 27, 2015 I have tried three of these locos and tried cv tweak and running in both ways all to no avail.I am no expert but I suspect the New sound decoder is the problem,I have three Railroad locos Mallard, Evening Star and Falcon, all run as smooth as silk, even on very slow speed but they are not sound.I returned all three locos and will wait to see if Hornby improve on the situation before I buy another one,a real shame as all other aspects of the loco are really good.It seems obvious by the amount of comments that this is a common problem and reflects badly on TTS Models as I have heard other TTS models,ie Cock of the North etc suffer the same problems.Still good value though, if you dont run your models at slow speed for realism.TED Link to comment Share on other sites More sharing options...
poliss Posted July 27, 2015 Share Posted July 27, 2015 There's all manner of CVs that can be adjusted. The TTS decoder manual is very complicated. Link to comment Share on other sites More sharing options...
poliss Posted July 27, 2015 Share Posted July 27, 2015 Looking at the CV settings. Algorithim 2. CV150=1 should help with low speed control.Also read what the manual says about CVs 153 and 154.Adjusting CV10 ) Back EMF) may help too. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 28, 2015 Share Posted July 28, 2015 Poliss, I hope you have more notice taken of this suggestion than they took when I made it 2/3rds of the way down page 1. We now have 8 posters and a model shop seemingly unable to solve this problem, despite many reporting it solved by changing algorithm soon after TTS locos were first released. And if my memory serves me correctly, the reports only mention changing CV150 with no one having to change the related P and I parameters or Back EMF to solve it. And not one of the 8 having reported here having tried it, or whether it worked. But then, what would I know, I have no TTS locos, in fact no skin in this game at all given all that can be at risk is another of Graskie's hats which I may be talking through. And only a very plain one of them at that - no need for corks, directional lights, flickering firebox glow or even custom sounds of a typical outback camp scene. But I digress. CV150 guys, read all about it on page 7 of your leaflet. Link to comment Share on other sites More sharing options...
poliss Posted July 28, 2015 Share Posted July 28, 2015 Think they call it Dither on my decoders. Uses a different set of CVs because the NMRA standards aren't really standard at all. Link to comment Share on other sites More sharing options...
m_duck Posted July 28, 2015 Share Posted July 28, 2015 I'm not so sure changing the CV settings will cure this problem for everyone. I bought a Duke of Gloucester and it wasn't the smoothest engine from starting off. After running in and applying oil it still wasn't as I would expect. After talking with the model shop I bought if from and reading on here I changed the CV150 setting and it did make an improvement. Not as smooth as some but I found it acceptable.I also bought a Cock o' the North and this was jerky when starting and even when running at a decent speed it would jostle the carriages. Again, I did the running in, oil, changed the CVs but it was never smooth. I returned it to the model shop who used it on their layout and agreed it didn't run as expected and returned it to Hornby. The replacement was a real improvement and ran as I would expect out of the box without the need to change any CV settings.I then bought Gadwall and this ran really well straight out of the box.So from my experience simply changing the CV150 setting might not fix the problem for everyone. I personally believe Hornby have had some not 100% TTS decoders but I can't prove it and it is only my opinion. .... but do try and change the CV settings as it can make a difference. Link to comment Share on other sites More sharing options...
Yasuda Posted August 26, 2015 Share Posted August 26, 2015 Sorry if I have posted this in the wrong place, I have read the comments regarding jerky motion as I have Tornado with TTS sound and mine exhibits the same symptoms at slow speed, reading TTS leaflet CV 150 has 2 options as already mentioned with CV150 set to 0 this is roughly equal to the characteristics of the Hornby Decoder using CV151/152 to adjust, or set CV150 to I (which on mine is stronger)CV153/154 are the ones to adjust here. Please note there is no CV155 on my chip! An error on the leafletI have ran Tornado in for 30 minutes each way and have managed by tweaking CV151/152 (CV150=0) to just about achieve a crawl but the loco is noisy. Moving on I unplugged the TTS decoder and replaced it with a Hornby 8248, the difference is amazing no jerking no noise, I think the problem is caused by the output of the motor section of the decoder maybe it's the frequency that's sent to the motor. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 26, 2015 Share Posted August 26, 2015 It would certainly seem there may be a problem with some TTS decoders but it is unlikely to be anything to do with frequency Link to comment Share on other sites More sharing options...
