Gearoid Posted June 25, 2015 Share Posted June 25, 2015 Hi Folks,I have had my elink since January and it woud appear to have just now given up the ghost! Elink light not working, tried disconnecting and reconnecting from the mains, still appears to have no life in it. Anyboy else have the same symptoms,Gearóid Link to comment Share on other sites More sharing options...
Teedoubleudee Posted June 25, 2015 Share Posted June 25, 2015 If no lights it could be the PSU. Have you checked the mains plug fuse? Link to comment Share on other sites More sharing options...
Chrissaf Posted June 25, 2015 Share Posted June 25, 2015 Rest In Peace !! - best cremated....... Do you have a multi-meter to check the output of the power pack on the DC connector plug. The plug that connects into the eLink. It should be 15 volts DC with the inner pin connector being positive and the outer sleeve being negative. If not, do you have a 12 volt car side light bulb that you can wire across the DC connector plug to see if it lights up..At least this would prove which of the two items (eLink or Power Supply) have gone faulty..If it was bought in January it will still be within Warranty, take / send it back for replacement. Link to comment Share on other sites More sharing options...
Gearoid Posted June 25, 2015 Author Share Posted June 25, 2015 Mains supply fine Tee, tks, will try Chrisaffs suggestion re PSU Link to comment Share on other sites More sharing options...
