daveyplod Posted July 5, 2015 Share Posted July 5, 2015 When I set Railmaster pro to set all points during start up, the results are variable. Some set properly to the correct direction and others do not. This is not consistent and when starting again it could be different points that set correctly. It seems to me that the delay between setting each point is less than 1 sec and maybe this should be nearer to 2 or 3 sec to allow the capacitors to re charge. Is there any way that I can alter the delay in the programme provided. I can, of course, write my own program with a longer delay, but I should be able to use the facitily provided. Any ideas?Dave A Link to comment Share on other sites More sharing options...
Chrissaf Posted July 5, 2015 Share Posted July 5, 2015 READ THE MANUAL - page 32.......relating to amending the railmaster.ini file..Extract of manual page 32 pasted below (see line in bold):."The default settings and descriptions are:-.Tipper speed=80 This sets the speed for the decoder chip running the tipperTipper timer=86.4 This is the number of seconds to run the tipper for a cycleTurntable speed=40 This sets the speed for the decoder chip running the turntableTurntable timer=19.30 This is the number of seconds to run the turntablePoints timer=0.75 No of seconds to pause between firing points rapidlyConveyor speed =65 This sets the speed for the decoder chip running the conveyorTCP start port=30 The IP starting port for networking/hand-heldsCheck serial ports=1 Whether DCC controller ports are checked on start-upShow upgrade button=0 Whether the upgrade....................................................".Modify the "0.75" seconds entry to the number of seconds of delay you want.....use Notepad.exe to make the edit. Link to comment Share on other sites More sharing options...
St1ngr4y Posted July 5, 2015 Share Posted July 5, 2015 Hi Davey,You do not mention what sort of accessory decoders you are using, but it's a fair bet they are R8247s. If you have a few of these, then it may be possible to change the firing order to allow the CDU on each AD to recharge. For example, if you have four decoders with port addresses 1-4, 5-8, 9-12 and 13-16, then if you set the firing order as follows, then you may be able to get away without editing the INI file:-Port Firing Order 1 1 2 5 3 9 4 13 5 2 6 6 7 10 8 14 9 3 10 7 11 11 12 15 13 4 14 8 15 12 16 16 Ray Link to comment Share on other sites More sharing options...
Nick_ Posted July 5, 2015 Share Posted July 5, 2015 I initially had exactly the same problem and as I have 4 R8247s I had set them up exactly as Ray suggested above, solved the problem for me. So I can agree that it works Link to comment Share on other sites More sharing options...
GWR Greg Posted July 6, 2015 Share Posted July 6, 2015 I am using DCC concepts point decoders but had a problem that one point wouldn't reset on start up. Having now read the above I have switched the starting position of the problem point with its neighbour and now all works okay.ie: 23,24,25,26 now 23,25,24,26 Link to comment Share on other sites More sharing options...
Teedoubleudee Posted July 6, 2015 Share Posted July 6, 2015 I am using DCC concepts point decoders but had a problem that one point wouldn't reset on start up. Having now read the above I have switched the starting position of the problem point with its neighbour and now all works okay.ie: 23,24,25,26 now 23,25,24,26 Are you using AD-S decoders Greg? If so I'm surprised as these decoders have a dedicated CDU for every port so shouldn't be a problem with waiting for capacitors to re-charge. Link to comment Share on other sites More sharing options...
GWR Greg Posted July 6, 2015 Share Posted July 6, 2015 Yes I am using AD-S decoders. I don't think the issue is with the decoders but a bug in Railmaster. I have reported this to HRMS but they have not come up with a solution. However for what ever reason swopping the order has sorted the issue. Link to comment Share on other sites More sharing options...
Teedoubleudee Posted July 7, 2015 Share Posted July 7, 2015 It would be interesting to know if you get a reply from HRMS, and what it says Greg. Link to comment Share on other sites More sharing options...
GWR Greg Posted July 7, 2015 Share Posted July 7, 2015 It was many months ago I reported it but should a reply appear I will post it. Link to comment Share on other sites More sharing options...
daveyplod Posted July 7, 2015 Author Share Posted July 7, 2015 Hi Davey,You do not mention what sort of accessory decoders you are using, but it's a fair bet they are R8247s. If you have a few of these, then it may be possible to change the firing order to allow the CDU on each AD to recharge. For example, if you have four decoders with port addresses 1-4, 5-8, 9-12 and 13-16, then if you set the firing order as follows, then you may be able to get away without editing the INI file:-Port Firing Order 1 1 2 5 3 9 4 13 5 2 6 6 7 10 8 14 9 3 10 7 11 11 12 15 13 4 14 8 15 12 16 16 Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted July 7, 2015 Share Posted July 7, 2015 Hi Dave,Did you mean to type something in your last post? Click the blue "Quote" button on this post, type your message in the white bit below the section with my message on a yellow background, then click the green "Reply" button.Ray Link to comment Share on other sites More sharing options...
Rog RJ Posted July 8, 2015 Share Posted July 8, 2015 Or scroll down and type your reply in the white box, then click the green "Reply" button. It's not always necessary to use the "Quote" button. Link to comment Share on other sites More sharing options...
96RAF Posted July 8, 2015 Share Posted July 8, 2015 Nor is it necessary to use the whole quote, you can copy and paste some of the preceding post into the white area like this, It's not always necessary to use the "Quote" button.Type your reply next like this and then highlight the quoted bit and click the 66 icon at the top of the reply box. Link to comment Share on other sites More sharing options...
daveyplod Posted July 8, 2015 Author Share Posted July 8, 2015 Ray, Thanks to you and everyone who responded to my points setting problemwithin Railmaster.Your suggestion of a "staggered"firinf order has worked like a charm. The process now repeats properly and so I can now depend on it.Thanks again,Daveyplod Link to comment Share on other sites More sharing options...
