john_booth Posted July 9, 2015 Share Posted July 9, 2015 a few weeks ago I purchased a brush type 2 or class 32 if you like, and it runs superb until it developed a squeak , now I cured that ok but being a little ham fisted I dislodged three wires at one end and don't know where to re connect them. The lights work fine on the other end. Please could anyone help. Regards John Link to comment Share on other sites More sharing options...
poliss Posted July 9, 2015 Share Posted July 9, 2015 Can't you work it out by looking at the connections on the other end? Link to comment Share on other sites More sharing options...
regork Posted July 10, 2015 Share Posted July 10, 2015 If your using DCC lights, Blue wire pin 7 is common + ve. White wire pin 6 is switched front lights. Yellow wire pin 2 is backup lights. Depending what you want rear light to show connect to relevent pin. Link to comment Share on other sites More sharing options...
john_booth Posted July 10, 2015 Author Share Posted July 10, 2015 Thanks guys I think I am getting there by checking the other end helps, but been waiting for a smaller soldering iron bit to arrive then I can get on with it. Thanks so far , regards JB Link to comment Share on other sites More sharing options...
john_booth Posted July 11, 2015 Author Share Posted July 11, 2015 Well lights are ok but now I have developed a squeal and it is proving very irritating , yes I have oiled as per instructions but it's very illusive, all ideas are welcome, regards JB. Link to comment Share on other sites More sharing options...
john_booth Posted July 12, 2015 Author Share Posted July 12, 2015 Ok so far found the squeal it was the fan blades in roof, now I have one issue that is that I have one black wire to re-connect which is black. The issue being that before my little accident the loco didn't stall on any of my points , and I have about 30. But now it stalled on about three of them. My question really is that do I have pick ups on both bogies and could this wire have come of one of them. Please could you help. If so I am not sure how to find and correct it. Regards John Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 12, 2015 Share Posted July 12, 2015 Black wire certainly sounds like it could be a pickup wire. The are usually red and black. Try looking at red and black on both bogies then see if you can figure out which one is missing the black and from where. Link to comment Share on other sites More sharing options...
john_booth Posted July 12, 2015 Author Share Posted July 12, 2015 thanks for tip, will give it a try, many thanks . Link to comment Share on other sites More sharing options...
john_booth Posted July 13, 2015 Author Share Posted July 13, 2015 Thanks to one and all, my class 31 is up and running. Regards John . Link to comment Share on other sites More sharing options...
RDS Posted July 13, 2015 Share Posted July 13, 2015 ... my class 31 is up and running ... Please don't leave us in suspense John, how did you fix it? Link to comment Share on other sites More sharing options...
Blackbird Posted July 20, 2015 Share Posted July 20, 2015 If your using DCC lights, Blue wire pin 7 is common + ve. White wire pin 6 is switched front lights. Yellow wire pin 2 is backup lights. Depending what you want rear light to show connect to relevent pin. Not so simple, the Cl 31 uses a complex circuit board to which the decoder is plugged into. No coloured wires to determine functionallity! and very difficult to determine circuit routes from decoder to terminals! Link to comment Share on other sites More sharing options...
Blackbird Posted July 20, 2015 Share Posted July 20, 2015 Not so simple, the Cl 31 uses a complex circuit board to which the decoder is plugged into. No coloured wires to determine functionallity! and very difficult to determine circuit routes from decoder to terminals! Link to comment Share on other sites More sharing options...
john_booth Posted August 6, 2015 Author Share Posted August 6, 2015 Sorry guys been to busy, what I meant was lights are ok and squeal is ok, bent fan blades a bit and it's ok , the fan was sticking, regarding pickup wire I found where it goes on bogie but how to get to it is another story. Sorry about late response, regards John B. Link to comment Share on other sites More sharing options...
john_booth Posted August 6, 2015 Author Share Posted August 6, 2015 Sorry about delay guys but been busy, I have sorted squeal out by freaing up the fan blades, I noticed that occ the fan would stick the the squeal would start and then fan would spin. Bent the blades a bit and sorted. She runs ok but stalls very occ on points and I know it's because of the pickup wire. I have found out which bogie but how on earth do I get into it to resolder it on again. Regards JB. Link to comment Share on other sites More sharing options...
john_booth Posted August 6, 2015 Author Share Posted August 6, 2015 ... my class 31 is up and running ... Please don't leave us in suspense John, how did you fix it? Hi guys sorry about delay but am pulled about six ways at the moment. The squeal was sorted by bending fan blades a little because I noticed every squeal was when fan had stuck and then freed itself the squeal then stopped. Regarding the wire that's come of well I have found its of one of the bogies, my problem is how can I get inside the bogie to resolder it on again. This very occ causes a stall on some points . Link to comment Share on other sites More sharing options...
john_booth Posted August 7, 2015 Author Share Posted August 7, 2015 I am having trouble posting, sorry for delay, when I can post again I will give more info. Regards JB. Link to comment Share on other sites More sharing options...
john_booth Posted August 8, 2015 Author Share Posted August 8, 2015 Just trying to post again. Link to comment Share on other sites More sharing options...
john_booth Posted August 9, 2015 Author Share Posted August 9, 2015 Hello rds, I have sorted out the squeal it was the fan sticking but my issue now is that it runs ok bar for the odd stall on points because pickup wire came off bogie and cannot see how to get to resolder it back on again, any help would be great thanks. Regards JB. Link to comment Share on other sites More sharing options...
john_booth Posted August 10, 2015 Author Share Posted August 10, 2015 I have fixed the squeal by freeing up the fan in the roof because it was sticking occ causing the squeal. The only problem now is how to get to solder back on a pick up wire onto bogie. Regards John. Link to comment Share on other sites More sharing options...
john_booth Posted August 28, 2015 Author Share Posted August 28, 2015 I take it the photos I sent weren't of any use, so let's leave it at that ok. Regards JB Link to comment Share on other sites More sharing options...
