anthony_middleton Posted July 14, 2015 Share Posted July 14, 2015 can i select cv settings using a hornby 'select', if so how Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 14, 2015 Share Posted July 14, 2015 Sorry Anthony, no you can't. Link to comment Share on other sites More sharing options...
tony_forward Posted July 14, 2015 Share Posted July 14, 2015 Anthony, Fishy is right, up to a point... There are SOME changes you can make with the select but they are very limited and you should download the select handbook from the web if you don't have one. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 14, 2015 Share Posted July 14, 2015 You can only change the functions covered by the Select Menu functions, but not directly a CV. For example, you can change a loco ID using this function on a Select. This in fact changes the value in CV1. However, you cannot directly put a new value into CV1 or any other CV like you can with a "real" DCC controller. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted July 14, 2015 Share Posted July 14, 2015 This should be in the DCC threads, really! Perhaps a Mod will move it, later? Link to comment Share on other sites More sharing options...
