Auto reverse
Ste9876
Your title says 'Auto Reverse'. If your question being asked is can the Hornby 'Select' controller be configured to take over control of the loco and run it in a pre-programmed manner, then the answer is NO. The 'Select' controller is a MANUAL controller. You would have to drive the loco manually between one station and the other.
Be also aware, that the 2 Car DMU would need to have a DCC decoder fitted (not just DCC Ready) for it to be controllable by the Hornby 'Select' as the 'Select' is a DCC controller.
The Hornby RailMaster / eLink DCC controller combination, CAN run programs and AUTOMATE the movement of a DCC Decoder fitted loco between stations, and is a similar price to the Hornby 'Select' controller but you need a PC to run RailMaster on as it is a software package.
While you cannot use a conventional DC shuttle module with a DCC console. You can obtain a module specifically for DCC that will shuttle a loco or train back and fore.  It is produced by a company called Tam Valley. Not cheap but it will work (Or it should!) with any DCC system, including the Select!  There are UK suppliers of Tam Valley products.
http://www.tamvalleydepot.com/products/trainshuttle.html
