daniel_kiely Posted July 25, 2015 Share Posted July 25, 2015 Do I need a different power track to run dcc because I have my digital pendilino set (the track was mixed in with stuff from other sets) and then I wired it all up and I have no control over the speed of the train or anything. I have 4 power tracks in total and they are all orange and I don't know which one is from the pendolino set so is it the power track that is wrong or something else? I'm not setting up permanently just to run my dcc locks in by the way thanks Link to comment Share on other sites More sharing options...
poliss Posted July 25, 2015 Share Posted July 25, 2015 The DC power track has a capacitor inside which interferes with the DCC 'signal'. It must be removed. Someone may be along shortly to tell you how to do it, or you may find the instructions using a forum search. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted July 25, 2015 Share Posted July 25, 2015 Chop out that yellow capacitor in the power tracks. They aren't needed for DCC and DC tracks work without them too. In power tracks its yellow, in power clips its blue, but either way its unnessacerry. A pair of side cutters are useful for this. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 25, 2015 Share Posted July 25, 2015 One piece of info missing here - the capacitor is inside the black box between the rails. Flip open the black cover, cut out the capacitor. Link to comment Share on other sites More sharing options...
daniel_kiely Posted July 25, 2015 Author Share Posted July 25, 2015 thanks. i know this may sound silly but im a bit of a beginner. i took the little plastic thing ff from between the rails and there is a blue square with some metal either side and i dont think its that. Is it in the box thing ( where you put the wires in) with the dots on top and if it is how do you get into it please? Link to comment Share on other sites More sharing options...
Howbi Posted July 25, 2015 Share Posted July 25, 2015 The DCC power track is R8241, the DC one is R8206 which is supposed to be fitted with the capacitor. I am now confused because I have 2 off R8206 on my DCC layout and have not experienced any problem because these pieces did not have capacitors fitted in the first place and my first one came with the Mixed Freight Digital Set. So Hornby, please explain........... Link to comment Share on other sites More sharing options...
poliss Posted July 25, 2015 Share Posted July 25, 2015 They're the same. It's just that one has a capacitor and one hasn't. Maybe they ran out of the digital numbered ones at the factory. Link to comment Share on other sites More sharing options...
daniel_kiely Posted July 25, 2015 Author Share Posted July 25, 2015 and where is the capacitor though Link to comment Share on other sites More sharing options...
Howbi Posted July 25, 2015 Share Posted July 25, 2015 Daniel, Fishmanoz has already told you......."One piece of info missing here - the capacitor is inside the black box between the rails. Flip open the black cover, cut out the capacitor."If there isn't one there then no problem.HB Link to comment Share on other sites More sharing options...
daniel_kiely Posted July 25, 2015 Author Share Posted July 25, 2015 Daniel, Fishmanoz has already told you......."One piece of info missing here - the capacitor is inside the black box between the rails. Flip open the black cover, cut out the capacitor."If there isn't one there then no problem.HB ok I was just confused because on my tracks it is blue Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 25, 2015 Share Posted July 25, 2015 If you've found it by flipping open the cover, it is the capacitor and the colour is irrelevant. Just cut it off from its 2 legs, throw it away and close the cover. You then have a DCC power track. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted July 26, 2015 Share Posted July 26, 2015 I found it to be blue on the clips and yellow on the power track, but it could be blue there too. its a small componant attached to both legs and doesn't need to be. cut it out and put it in the bin. XYZ Link to comment Share on other sites More sharing options...
