Nictor Posted July 26, 2015 Share Posted July 26, 2015 Just gone back to useing a Hornby select on my n gauge test layout and it seems to be making a very slight hissing type of noise when connected. Loco's all work fine. I don't remember it doing this before on my old oo gauge shelf layout. Any ideas? Link to comment Share on other sites More sharing options...
sparkhill Posted July 26, 2015 Share Posted July 26, 2015 Maybe a loose fitting power plug on the power supply, its cooking an insect or chucking a hissy fit because it wants to be connected to big engines, either way check the power plug and socket are a tight fit or give it some time and see if it settles down itself, if its working OK its highly unlikely that any components on the circuit board are cooking. Link to comment Share on other sites More sharing options...
Teedoubleudee Posted July 26, 2015 Share Posted July 26, 2015 I believe electrolytic capacitors sometimes hiss just befor they blow up. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 26, 2015 Share Posted July 26, 2015 Not for long, that would be the insides on their way outside, and wouldn't take long. Link to comment Share on other sites More sharing options...
poliss Posted July 26, 2015 Share Posted July 26, 2015 I've heard of high pitched buzzing, but never hissing. Maybe a snake is trapped inside? Link to comment Share on other sites More sharing options...
Graskie Posted July 27, 2015 Share Posted July 27, 2015 Do you know, I daren't suggest that myself, poliss? I thought I myself would get hissed at for doing so. Link to comment Share on other sites More sharing options...
sparkhill Posted July 27, 2015 Share Posted July 27, 2015 I have three Select controllers and they all make a hissing sound, could be because I have had Tinnitus (ringing or hissing in the ears) for 18 years, caused by using a rock drill in a tunnel 8 hours a day for years. Link to comment Share on other sites More sharing options...
Michael_A Posted July 27, 2015 Share Posted July 27, 2015 Bear in mind the system works using a high frequency supply to the track, which is then pulse wave modulated to control the motors. Even the output of the decoders operates at about 18Khz. It could be that some of the cpmponents have just become a little noisy, or you have good ears! Given the way high frequency sound travels, simply having the controller in a dieffernt location can change how / if you hear the sound. If you are worried, have it checked out. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted July 27, 2015 Share Posted July 27, 2015 I used to be able to hear a tv's whistling crt time-base. I can't now, though, I don't have a tv!Try putting the Select on a different surface, and see if that deadens the whistle/hiss. Link to comment Share on other sites More sharing options...
Nictor Posted July 27, 2015 Author Share Posted July 27, 2015 Been useing it today with my Hornby Rolling Road. Putting some 'big' OO Hornby locos on eBay. Still hissing at a very low volume. Has not blown up. Need to send it to Hornby anyway for the latest update so I'll get them to check it. Thanks for all replies. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted August 17, 2015 Share Posted August 17, 2015 It's snoring, its asleep.Check for short circuits, that will cause a hissing noise.XYZ Link to comment Share on other sites More sharing options...
