Digital Track Maintenance
Waresy
I've got some digital track so I have 2 questions;
Are there any particular hints and tips to keeping it running smoothly above that of normal track.
I have a pit lane right hand side which the entry lane switcher doesnt reset to the standard straight lane, so once you have decided to pit once it remains directed to the pit lane.  Any idea on how to check/clean/repair this?
It's only about a year old but  a key part of my layout.
  • 2 months later...
I've looked online for the Inox-MX3 and it isnt the most available product in the UK.  I've seen it recommended in a few of the posts on here so would it be possible for Scalextric/Hornby to stock it so we have a reputable seller to buy it from?
It's not even available on Amazon which have alsorts!
Does WD-40 come under one of the suitable 'equivalent'?
Cheers
I had the same experience (I live in Germany). On the Inox site it does say there is a supplier in the UK in Poole I think. I founf  French supplier but it was 25€ a can.
Ona U.S. you tube channel they said it was $7.95 so 25€ is a heck of a hike.
Inox MX3 is made of some food by product so it is safe to eat (technically) and WD 40 is petroleum based. WD 40 also attacks the plastic as well as soaking in making it slippery.
I am also looking for an alternative. I have found a German product calle Ballistol that might fit the bill as it says it is safe to use on animals (!?!) but I have to find the chemical breakdown to see if they are similar or not.
What I have been using is automatic transmission fluid with Dextron in it. It is specifically designed to not allow corrosion. I apply it very very sparingly and carefull on my rails after cleaning them with alcohol and drying them off.
It seem to help but I make sure not to get any on track. It is not as aggressive as WD 40 but it is a lubricant so you don't want tires getting on it if you can help it...
My track is all analog BTW....
Hi, I have a permanent digital track in my garage, i swear by using wd40 on the rails and track, avoid the oil slipping down between the flippers though. I find by using wd40 gives good grip from the track and good traction for the tyres. I spray some on a clean cloth and wipe it in.
  • 10 months later...
Just stumbled over this post.... I have just bought some Inox frpm Australia.  Looks cheap at about £6 per 125ml bottle.  Total about £17.00 for three bottles.  Plus P+P (£20.00) and 'Customs' rip off (£20.00), so,say £20.00 per bottle.  Now, I have tried WD40 and all sorts of things to keep all running smoothly on my Scalextric Sport permanent layout which, by the way, is copper taped.  All have worked to a certain degree, but this stuff.......WOW!!!!!
For a supposed di-electric corrosion inhibitor, it does a brilliant job!  Spray on to the pick-ups and just watch the difference.  The cars spread it over the track contacts as they go round.
Worth every penny!
Chas
