Smithy58 Posted August 1, 2015 Share Posted August 1, 2015 good dayi have an Dapol n gauge class 66 diesel which seemed to oddly run very very slow at full power without any load. I have looked at the manual and checked out the speed factor section just as a hunch. So I timed it to travel approx 1.8m at 18 s thereabouts. I entered this (18) into the speed factor box and whoosh of it went, I just feel it is a bit too fast now, my question is what would have been the default setting before I would have changed it?regardsColin Dell PC laptop, elink, Railmaster Narrow gauge layout. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted August 1, 2015 Share Posted August 1, 2015 Have you ensured that N scale has been selected for your RailMaster setup?Also, did you set up the recommended length of N scale track in a loop and run the timings from that, allowing your loco to warm up and measuring it at constant full spedd (no acceleration/deceleration included)?Also, did you ensure you created a new loco and did not select a Hornby loco from the built-in list? Doing the latter would apply the wrong scale speed profile for your N scale non-Hornby loco. Link to comment Share on other sites More sharing options...
