ARC Direction Switch?
Hi. Does the Arc one  power base come with a switch to reverse direction ?
Reason - I have an anologue long track which I have wired up via a switch(was a tricky mod) which means I can run races in either directions by a flick of a switch.
Or would I need to have 2 powder bases fitted to track to run in opposite directions  and run the actual mains power feed via a switch so they could not both be powered up at the same time. Obviously you would need to plug controllers into whichever one is switched to power.
  • 3 years later...
