IJG Posted August 9, 2015 Share Posted August 9, 2015 I have only just installed Railmaster with elink and have been playing as you do. I have created a track plan which was straight forward enough but I am having real problems on how to edit it once it is saved. I cannot find any reference in the manual and have pressed every button and searched every menu that I can. I would be grateful if someone could point me in the correct direction as I am sure you must be able to do it Link to comment Share on other sites More sharing options...
GWR Greg Posted August 9, 2015 Share Posted August 9, 2015 Simple lick the triangle symbol, forth one along, design a layout. Once open select your plan from the list at the bottom and away you go. Link to comment Share on other sites More sharing options...
Yelrow Posted August 9, 2015 Share Posted August 9, 2015 HI, click triangle symbol, but remember your plan needs a name. I looked at the ones in this list, picked one, and modified it EG hornby track plan 9, johns version. Welcome to the forum. The other nice thing to play with, is the Double Header, where you join 2 locos, and they run as one. Its on top of screen, in list. john Link to comment Share on other sites More sharing options...
IJG Posted August 9, 2015 Author Share Posted August 9, 2015 Thanks for the replies and the welcome. I thought I was going mad initially, even though you have told me where to look, I couldn't see any lists !!!! Then I realised that the design screen was waaaay to big and i couldn't see the top or the bottom, minimised the screen and there it was ...... Many thanks.As I don't have a 5 year old to show me how this works, I quess there will be lots of questions in future.Ian Link to comment Share on other sites More sharing options...
