Lesdavis Posted August 10, 2015 Share Posted August 10, 2015 I have just purchase the city of coventry it is set to default address 003 using the elite i reset tge address to 0010 fine every goes through red light flashes etcthen when i select loco it will not move or the sound function will not work this will happen for any address but when i get back to default address 003 press loco and it works and the sound functions but instead of displaying the address it displays C37 696 why what is the problem it only affects this loco in this way Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 10, 2015 Share Posted August 10, 2015 Clearly you have failed to reprogram the loco. Suggest you try again with only the programming track connected, not the layout and try a little pressure onto the loco as you try. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted August 11, 2015 Share Posted August 11, 2015 And clean the track, the wheels, and the pick-ups. It only needs a trace of muck to corrupt the programming data.Perhaps admin will move this to the DCC threads and change the title to Decoder - not decorded!? Link to comment Share on other sites More sharing options...
Augustus Caesar Posted August 11, 2015 Share Posted August 11, 2015 Also check the wiring to the programming track for a firm grip and that they are not loose. Some changes may be made but not completed if the wiring is making a circuit but is breaking that circuit infrequently... i.e. loose connection. Link to comment Share on other sites More sharing options...
