Trigger sound without DCC - is it possible?
It's a Bachmann USA steam loco. It just does the basic ticking over, whistle/ bell as it moves and chuff sound. Can't control the sound, there are 21 in all but I can't access them. Trouble is it drives me up the wall after a minute or two but I can't switch it off. I don't run it very much, only to show people really.
The original QSI sound systems used in the first Broadway-Limited locos were designed to operate in DC. Flipping the REVERSE switch while the loco was moving would trigger the whistle and bell. Then they came out with a "box" that hooked inline with your DC controller that accessed ALL of the sounds with DC. THEN MRC came out with the "Black Box" that wired inline with a DC controller that provided just about all of the normal DCC functions except programming. If you don't want to go DCC, the Black Box is a good alternative for about $50. As long as your loco is set to address 3, you can access all your functions (including throttle and reverse). I'll sell you one if you want it. by the way, with the Black Box, you technically ARE DCC, so you can't run DC while the "Box" is being used.
