badgers Posted August 19, 2015 Share Posted August 19, 2015 hi got 8 points ,two ass decoders r8247, and and elite control unit,only one point of conection for track,where do you connect decoders ,for control point,is it the track or do you make a juntction box system, too make them work ,any one can you help ,nothing in book about it , badgers Link to comment Share on other sites More sharing options...
Michael_A Posted August 19, 2015 Share Posted August 19, 2015 This should be in the DCC forum section, but reply is easy. The decoders need connecting to track to 'charge them' then to the programming connections of your Elite to programm them. Once programmed, all decoders connect to the track. See page 58 of the manual....... Link to comment Share on other sites More sharing options...
badgers Posted August 19, 2015 Author Share Posted August 19, 2015 This should be in the DCC forum section, but reply is easy. The decoders need connecting to track to 'charge them' then to the programming connections of your Elite to programm them. Once programmed, all decoders connect to the track. See page 58 of the manual....... Link to comment Share on other sites More sharing options...
badgers Posted August 19, 2015 Author Share Posted August 19, 2015 hi michael, only problem with that is the book i have only goes up too page 50,is there a upto date book with more padges,if so where do i find it Link to comment Share on other sites More sharing options...
badgers Posted August 19, 2015 Author Share Posted August 19, 2015 hi again ,have down lowded new elite book and it still does not show where you make connection i think the only way is too add another power connection section so as too take a connection back too the point decoders, as i can not see any other way may i be correct Link to comment Share on other sites More sharing options...
Rog RJ Posted August 19, 2015 Share Posted August 19, 2015 Oops! Posted in error Link to comment Share on other sites More sharing options...
Howbi Posted August 19, 2015 Share Posted August 19, 2015 Go to this page, scroll down to R8247 Point & Accessory Decoder, download and print out.https://www.hornby.com/uk-en/downloads/view/index/cat/3/ Link to comment Share on other sites More sharing options...
Michael_A Posted August 19, 2015 Share Posted August 19, 2015 hi again ,have down lowded new elite book and it still does not show where you make connection i think the only way is too add another power connection section so as too take a connection back too the point decoders, as i can not see any other way may i be correct The instructions don't tell you where on the track because actually it doesn't really matter. My advice however would be to connect it as near to the power feed to the track as possible if you can, or even directly to the Elite track connector. DCC is a two wire system, pretty much everything picks up power from the track or track connection. Remember to programme it though it needs connecting too the track first, disconnecting and connecting to the Elite programme connectors, then once programmed, back to the track. Good luck. Link to comment Share on other sites More sharing options...
Howbi Posted August 19, 2015 Share Posted August 19, 2015 Why not use power feed rail joiners nearest to decoder positions. Simplest solution. Link to comment Share on other sites More sharing options...
badgers Posted August 21, 2015 Author Share Posted August 21, 2015 well have sorted it out in the end put a new power connetion line in system and it all works good now thanks for all your help guys , Link to comment Share on other sites More sharing options...
