kevan_adams Posted August 25, 2015 Share Posted August 25, 2015 My question is to the forum is, can i use USB - rj12connection of the select unit to a PC for control, i have noticed that on the back of the select unit you use an RJ12 to connect to an Elite unit. can i use this same jack to connect via a usb connector to the Pc. many thanks Kevan Link to comment Share on other sites More sharing options...
pidder Posted August 25, 2015 Share Posted August 25, 2015 Ooooh wishful thinking...try it and let us know what happens... Link to comment Share on other sites More sharing options...
RB51 Posted August 25, 2015 Share Posted August 25, 2015 No don't try it - the Select cannot be connected to a PC. Not without pyrotechnics anyway! R- Link to comment Share on other sites More sharing options...
Howbi Posted August 25, 2015 Share Posted August 25, 2015 Surely you would need an Application on the PC to send relevant commands to the Select unit ie: Hornby RailMaster. That is if the Select is ok for connection this way. Link to comment Share on other sites More sharing options...
Rog RJ Posted August 25, 2015 Share Posted August 25, 2015 My question is to the forum is, can i use USB - rj12connection of the select unit to a PC for control, i have noticed that on the back of the select unit you use an RJ12 to connect to an Elite unit. can i use this same jack to connect via a usb connector to the Pc. many thanks KevanNo.If you try it you will probably damage the Select or the PC or both. Don't do it. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 25, 2015 Share Posted August 25, 2015 I have noticed that on the back of the select unit you use an RJ12 to connect to an Elite unit. can i use this same jack to connect via a usb connector to the PC..The RJ12 on the rear of the Select is an ExpressNet interface and completely different to USB..As an analogy your question is a bit like asking can I connect my water supply pipe to my gas pipe. Yes they can be made to physically mate together via an adapter, but passing water through the gas pipes is not going to be very good for any attached gas appliances. Link to comment Share on other sites More sharing options...
pidder Posted August 25, 2015 Share Posted August 25, 2015 Just to clarify, what is the purpose of this RJ12 output on the Select? As an aside, Windows is now so powerful, if a PC recognises a Select as some form of device, I would expect Windows to search high and low for any software needed. Don't try it unless you have a disposable Select and PC, but it would be interesting to hear a result... Link to comment Share on other sites More sharing options...
Rog RJ Posted August 25, 2015 Share Posted August 25, 2015 The RJ12 connector allows the Select to be used as a walkabout controller. The Select will be a slave controller when it is connected to an Elite, the Elite will always be the master but a Select can also be used as a slave unit when connected to another Select. In this case, any one of Selects can be designated as the master.An alternative use of the RJ12 connector is to connect a power and signal booster. Link to comment Share on other sites More sharing options...
poliss Posted August 25, 2015 Share Posted August 25, 2015 As Rog says. The output is for connecting it to the Elite or to connect another Select as a Walkabout. A booster can also be connected.It cannot be used to connect a computer. It will not be recognised. Don't bother tryong to. Link to comment Share on other sites More sharing options...
