Chrissaf Posted December 29, 2017 Share Posted December 29, 2017 The traction tyres (rubber wheel traction thingies) may have become stretched over time and are not sitting tightly on the wheel treads. You therefore may need to approach an N gauge specialist dealer to try and find out if these are still available, and fitting them will also require some skill as it may be necessary to dismantle the locomotive. You may need to re-post this in the International section which is more likely to be read by Arnold users. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 10, 2018 Share Posted January 10, 2018 i have an older aronold n scale 262 steam engine & tender #23 105, its red and black. seems it had rubber wheel traction thingies on it (1/2 there?) (looke like), Anyway it still runs but seems bouncy and i wanna fix it up, can someone help out? Thx Link to comment Share on other sites More sharing options...
Chrissaf Posted January 10, 2018 Share Posted January 10, 2018 Moved here from the 'Engine Shed' forum as suggested by LC. Link to comment Share on other sites More sharing options...
Rana Temporia Posted January 11, 2018 Share Posted January 11, 2018 If only part of the tyres are there the wheels will be bouncing along the track an you’ll need new ones. If you take them off totally the wheels will probably have grooves in them and again won’t run smoothly. Link to comment Share on other sites More sharing options...
