Dazzler down under Posted January 8, 2012 Share Posted January 8, 2012 hi all,got myself this for christmas only to find that after 2 weeks the sign on the side that says obsevation car has started to peel off one side,only a minnor problem i think,but was wondering if anyone could suggest a good quick but perminant fix,would superglue work?returning to the shop is not an option as i purchased it from this website and live in oz.any suggestions much apreciated. Link to comment Share on other sites More sharing options...
riwaka Posted January 8, 2012 Share Posted January 8, 2012 Supeglue can sometimes leave a white residue on certain plastics - spreading some distance away from the small bit that you have glued. Never use superglue near clear platic windows for this reason - they will turn frosty. I would try a small bit of PVA glue for the sign on the observation car. It takes longer to dry, but will definitely dry clear. You will also have time to adjust the position of the sign - no chance of doing this with superglue.Good luck Link to comment Share on other sites More sharing options...
VESPA Posted January 8, 2012 Share Posted January 8, 2012 Try Pritt that will work and not mark. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 10, 2012 Share Posted January 10, 2012 Try photo glue - from your local crafters/card making shop.It is a very thin, non-toxic, non acid glue that will not soak through and stain photographs, hence the name! Link to comment Share on other sites More sharing options...
