Darthtrainspotter Posted December 12, 2018 Share Posted December 12, 2018 Hellohad a bit of a nightmare posting due to predictive text so apologies so are are peco insulated frog points the same as hornby and can you use the same metal clips when using dcc to make them live cheers Link to comment Share on other sites More sharing options...
jane1707819582 Posted December 13, 2018 Share Posted December 13, 2018 basically yes ,the issue i have had with peco is the hornby surface point motors 8243 struggle to pull the points Link to comment Share on other sites More sharing options...
Nick_ Posted December 13, 2018 Share Posted December 13, 2018 If you are talking about Peco SetTrack points then yes they are almost identical to Hornby points And you can use the metal clips without a problem.On the other hand however Peco’s streamline points, both insulfrog and electrofrog, have a different radius. If you use streamline points then I would recommend using dropper wires as the Hornby metal clips don’t fit them very well. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 13, 2018 Share Posted December 13, 2018 Just to add a bit more meat on the bone. Peco track products that start with the letters ST (for Set Track) can be used in place of Hornby track. Link to comment Share on other sites More sharing options...
Darthtrainspotter Posted December 13, 2018 Author Share Posted December 13, 2018 Just to add a bit more meat on the bone. Peco track products that start with the letters ST (for Set Track) can be used in place of Hornby track.Thanks to you all. I ran a few tests with multimeter and clips and locos all seems good. Thanks Link to comment Share on other sites More sharing options...
