beppearma Posted December 23, 2018 Share Posted December 23, 2018 hi all, I bought a mallard live steam (new never used) I mounted the track properly, properly mounted the power supply, filled the tank with water and even the oil, in short, I did everything as the manual requires, checked more 'times I've done everything correctly, but when I turn the power handle on super heat the red light does not come on in the train cabin and not even on the control panel, what can I do? I thank anyone who can help me in advance Link to comment Share on other sites More sharing options...
beppearma Posted December 23, 2018 Author Share Posted December 23, 2018 hi all, mallard live steam help. wheels turn hard and the control panel and the red light in the cabin does not come on, what can I do? Link to comment Share on other sites More sharing options...
Go_West Posted December 23, 2018 Share Posted December 23, 2018 Hi what is the volt meter reading Link to comment Share on other sites More sharing options...
beppearma Posted December 23, 2018 Author Share Posted December 23, 2018 Hi what is the volt meter readingthanks for writing me, reading is always zero, not even a hair moves Link to comment Share on other sites More sharing options...
Go_West Posted December 23, 2018 Share Posted December 23, 2018 Hihave you switched ON the power at the controller this is the rocker switch at the back of the controller?when this is ON the red light in the front top left hand corner above the volt meter will be powered up.if this light has not come on check the out put on the power unit by testing the output pins in the unit with a volt meter or 12 volt car bulbif this bulb lights up then check the wiring in the main cable from the power unit to the controller you can use the 12 volt bulb againif power is at the power lead end to the controller the the fault is in the controller Link to comment Share on other sites More sharing options...
