Racersteve39 Posted February 15, 2019 Share Posted February 15, 2019 Each controller has 2 flat copper connectors with a hole inside/media/tinymce_upload/3025d35208b271262cb37222956d71ac.jpg/media/tinymce_upload/283ef026d24939b57d620e336e85c837.jpg Link to comment Share on other sites More sharing options...
woodcote Posted February 18, 2019 Share Posted February 18, 2019 Hi Racer Steve - welcome to the forum! The two terminals at the front of the big black transformer should have nuts on them that unscrew. Simply unscrew them and then slide one copper connector (with the hole inside) from each controller onto each terminal. Keep the same colour wire together - white or red. Replace the nuts and tighten them up. Each controller also has a red plastic connector with two copper pins. This goes underneath the track where there are square holes in the plastic so the copper pins fit. If you put the red connectors the same way round on each lane, the cars should run in the same direction. To change direction, just flip the red connectors round 180-degrees. I hope that helps you get the set working. Link to comment Share on other sites More sharing options...
