DeeJayEye Posted June 3, 2019 Share Posted June 3, 2019 Has any owner of this loco opened it up and if so is there room inside to fit a speaker and of what size? Link to comment Share on other sites More sharing options...
Bulleidboy Posted June 3, 2019 Share Posted June 3, 2019 Hornby Magazine did an in depth article on fitting sound to the H Class Wainwright. It was quite a job, with the decoder socket being removed and the mounting lugs being reduced in height, so a bit of butchering to be done. There are a number of YouTube videos showing what it sounds like, but have not found one showing how to fit it. Link to comment Share on other sites More sharing options...
JJ73 Posted June 3, 2019 Share Posted June 3, 2019 Here is an idea - instead of opening up the Loco - why not get hold of an old Carriage & insert the speaker inside the Carriage instead of the loco??? Link to comment Share on other sites More sharing options...
DeeJayEye Posted June 4, 2019 Author Share Posted June 4, 2019 Hornby Magazine did an in depth article on fitting sound to the H Class Wainwright. It was quite a job, with the decoder socket being removed and the mounting lugs being reduced in height, so a bit of butchering to be done. There are a number of YouTube videos showing what it sounds like, but have not found one showing how to fit it. Thanks, I must ahve missed that in the magazine, mind you it was 18 months before my model actually arrived. Link to comment Share on other sites More sharing options...
DeeJayEye Posted June 4, 2019 Author Share Posted June 4, 2019 Here is an idea - instead of opening up the Loco - why not get hold of an old Carriage & insert the speaker inside the Carriage instead of the loco???I'd rather not have the trailing wires but thanks for the suggestion. The loco has to be opened for the dcc deoder anyway. Link to comment Share on other sites More sharing options...
Bulleidboy Posted June 5, 2019 Share Posted June 5, 2019 If you still have it, it was in the January 2018 edition of Hornby Magazine. In very simple terms, the speaker (Sugarcube) was placed on the cab floor, the decoder lugs were cut away, and the sound decoder, with wires shortened drastically, was hard-wired in place, and located in the original position, but lower as lugs removed. If you decide to go without sound, a direct fit decoder seems to be the best solution - not a lot of room for the harness. Link to comment Share on other sites More sharing options...
SteveM6 Posted June 5, 2019 Share Posted June 5, 2019 Fitting decoders to tank locos is becoming increasingly difficult when it comes to finding space. And sound is virtually impossible unless you spend more on a decoder than you spent on the loco itself!Hornby have made a big investment in TTS (I know they are not perfect, but they are affordable and more than adequate for many users) but surely the time has come for them to miniaturise them for expansion into smaller locos - and supply them without the speakers.And manufacturers really do need to ensure that their DCC ready locos really do allow sufficient space to fit a decoder. Link to comment Share on other sites More sharing options...
Hairy Posted June 8, 2019 Share Posted June 8, 2019 YouChoos have a installation guide on their website. Link to comment Share on other sites More sharing options...
