Dusty Dave Posted July 9, 2021 Share Posted July 9, 2021 The old 70's issue Crusader is showing it's age but a great miniature can still result from this kit if little care and attention is placed on it's construction.the first thing to be aware of is the rather weak mounting points for both the sprocket and idler wheels, these have to take the strain of the elastic band type tracks, so a slight modification is needed to beef up their mounting.either by using two part epoxy resin glue, or by drilling and inserting strengthening metal pins/dowels, the sprocket and idler wheels must be left to dry and harden off before any attempt is made to place load on them.when you are happy to move on, the tracks are assembled from four lengths (two per side) I use a staple gun and a pair of pliers to flatten the staple right down, they can be camouflaged with paint and mud/sand.the top details are quite realistic, the air filter is well represented as is, and needs no modification. Link to comment Share on other sites More sharing options...
Ratch Posted July 9, 2021 Share Posted July 9, 2021 I don't recall any problem with the sprockets Link to comment Share on other sites More sharing options...
