Paul Gerhard-1219017 Posted August 26, 2021 Share Posted August 26, 2021 Is there a change to get 3-unit Ferrobus as Hersfelder Kreisbahn version?If yes - I like to be informed about ist right in time.Thanks a lot in advance.Paul Link to comment Share on other sites More sharing options...
ellocoloco Posted August 26, 2021 Share Posted August 26, 2021 Hi Paul,If the Renfe 591 is the same as the VT54 then maybe it will appear under the Rivarossi label for the German market. (I would imagine Hornby would make as much use of the tooling as they can.) If this was to be announced it would most likely be in January along with the rest of Hornby and Hornby Int'l's proposed new releases.(Hornby may not know that the HKB VT 54 was derived from the Renfe version so it may well be worth letting them know..............)You could always buy the Electrotren version and repaint it! Link to comment Share on other sites More sharing options...
