1930 1/12th scale Bentley 4.5ltr.
Factman
I have the most recent issue of this kit. So far so good, but now I need to connect the propshaft to the back axle differential. Part 106 is the connecting piece, the square end of the shaft is bigger than the square socket in 106. The rear ended of 106 which mates with the back axle differential, 105, has a larger square socket, but nothing seems to mate with it. Has anyone seen a similar problem.
Why didn't you add this to your previous post instead of making multiple threads on the same topic?
And no, I don't know the answer. I made it a long time ago (someone ese had started the kit) and don't remember your problem.
