Glue Slate Model Base
Snow Slate Model Base
Model base built using balsa wood cut to size.
sand block for middle glue balsa wood cut to size to edges of the sand block. Apply slight pressure to each sides to ensure glue remains intact
once sides remain in place after glue set. Apply glue all over the top of the sand block. While still glue wet apply Slate all over the base of the sand block. Leave the glue to set overnight.
while the glue is drying. You could build a model for the base 172 Scale Models are ideal size for this. I am building one of Airfix Tiger 1 Tanks. I am painting this white as shown in the instructions paint sheet.
