Nathan -355727 Posted February 13, 2023 Share Posted February 13, 2023 Hi All I am new to the hobby, after reading a number guides on painting/varnishing I am still a little confused.I plan to hand paint with Arcrylic,apply a gloss varnish, apply decals, weather with enamel and varnish again with Matt/Satin.I believe I need to use the opposite varnish to the paint, my confusion is which type of varnish to use (Arcrylic /Enamel) and when? Maybe I’m missing a step or over thinking it all. Link to comment Share on other sites More sharing options...
Ratch Posted February 13, 2023 Share Posted February 13, 2023 I believe I need to use the opposite varnish to the paint, my confusion is which type of varnish to use (Arcrylic /Enamel) and when? Maybe I’m missing a step or over thinking it all. Probably over thinking.I use acrylic paints. I spray on an acrylic varnish to seal, then weather with powders using white spirit (same as enamels) and then seal with acrylic matt. No problem. Link to comment Share on other sites More sharing options...
Nathan -355727 Posted February 14, 2023 Author Share Posted February 14, 2023 Hi Ratch, thank you for your replay. Link to comment Share on other sites More sharing options...
Ratch Posted February 14, 2023 Share Posted February 14, 2023 Let us know how you get on, Nathan. Link to comment Share on other sites More sharing options...
Nathan -355727 Posted July 19, 2023 Author Share Posted July 19, 2023 So I finally got around to building a Tiger 1, I took my time and was very pleased with my build and hand painting however I decided to seal the paint with Humbrol acrylic Matt varnish spray, on my return a day later I noticed lovely desert tank had almost turned white and had an almost bleached look! What did I do wrong? Link to comment Share on other sites More sharing options...
Ratch Posted July 19, 2023 Share Posted July 19, 2023 Unfortunately, aerosol varnishes sometimes have this effect. The whitening is caused by too much matting agent. You might try applying a gloss varnish over it and it may have the desired effect. I had a similar problem with this one. Link to comment Share on other sites More sharing options...
Nathan -355727 Posted July 19, 2023 Author Share Posted July 19, 2023 Thanks Ratch, I panicked and tried to paint over it but may if made the paint job worse, I may need a few coats, I could also try to weather it, Link to comment Share on other sites More sharing options...
Nathan -355727 Posted July 20, 2023 Author Share Posted July 20, 2023 I have some Mig lucky Matt varnish, but it’s for an air brush, I assume I could lightly paint it on? My model is tarnished anyway now, some I’m using it for testing weathering etc. Link to comment Share on other sites More sharing options...
