Raymond Paul -362616 Posted July 26, 2023 Share Posted July 26, 2023 Hi I’m just starting modelling again, I have done this since I was a child and I’m now coming up to 60 my question is, is better to paint the parts that I need attached to the firm sections or take them from first ?? anyone’s help would be greatly appreciated thank you Link to comment Share on other sites More sharing options...
vimal_indrasoma Posted July 30, 2023 Share Posted July 30, 2023 Hello - your question isn't quite clear, but I assume you mean whether to paint the parts before or after cutting them from the sprue.In general, I prefer the paint the larger parts such as bodywork after assembly so that the seams and any other defects can be covered up first. Assemble, primer, sand, filler, sand, paint is best.For the tiny parts such as handles and such, it's easier to paint on the sprue and touch up later if any of the attachment points are visible. Another option is to cut the part out, clean it up and superglue a toothpick or pin to a spot that won't be visible and use that as a handle while painting, You can stick the 'handle' into a lump of modelling clay while it dries. Link to comment Share on other sites More sharing options...
