81F Posted August 6, 2023 Share Posted August 6, 2023 I have a spare Wrenn N2 which has lost its original triang type couplings to which I would like to fit a set of PECO/Doublo couplings so it can pull my collection od Hornby Dublo wagons.I recall my original N2 had a conversion pack so I know it is possible but that is long gone so I am trying to collect the bits I need and just want some confirmation that I am heading in the right direction and advice on components.The original triang front coupling was held on by a solid brass shouldered rivet, Am I right in that all I need to do is get one of the push on plastic couplings to clip around the shoulder. If yes would this be the straight or cranked type?However, the pony truck is presenting some a problems as follows: I have recently purchased a conversion back which contains a self tapping screw, brass collar and straight coupling. I know it will fit the R1 but I do not know if this is correct for the N2. - will I need to get a cranked coupling?The original lug that he;d the origina; triang coupling is getting in the way, so will need to be removed, but what is the best option. Do I file the lug down flush with the bracket which sticks out from the back of the pony truck or do I simply cut the bracket off?Having tried to self tapping screw into the hole in the pony truck I find that it is so tight that I risk damaging the head or shearing the screw. Should I therefore try to obtain a brass coupling revit (of which several are available on eBay) or simply open out the hole in the pony truck slightly?If using the rivit what size should I get or if using the self tapper can someone suggest a size of drill (I guessing that it would be the tapping size for the pony truck screw but this seems larger.Many thanks for any help you can give. Link to comment Share on other sites More sharing options...
Tony57 Posted August 6, 2023 Share Posted August 6, 2023 Hi 81FI have the same issue in regards to a N2.One option I am looking at is getting a HD N2 rear bogie unit with it HD coupling.I need to look at my N2s to see what can be done Link to comment Share on other sites More sharing options...
Tony57 Posted August 6, 2023 Share Posted August 6, 2023 HiWith regards to using a rivet what type of coupling are you thinking of using metal or plastic?As there are at least 3 maybe four rivets available, 2 are shouldered for plastic and are of two different lengths, the orther/s are the same only shouldered for the metal couplings .Have a look at the Wrenngalore shop or cymull_76 both sell HD /Wrenn bits Link to comment Share on other sites More sharing options...
Rana Temporia Posted August 7, 2023 Share Posted August 7, 2023 If you simply add a PECO coupling the height will be wrong. Best solution as far as I am aware is a replacement HD rear bogie. There are usually plenty on eBay for very little. You can keep the old one as a spare then. Link to comment Share on other sites More sharing options...
81F Posted August 7, 2023 Author Share Posted August 7, 2023 Many thanks for the idea of using an old Hornby one but it wont fit unless Hornby produced two radically different chassis for their N"s. Having up ended my Father's Hornby Dublo N2, It was immediately obvious that the distance between the pony truck pivot and the trailing wheels is considerably longer than that of the Wrenn loco.In addition the arm through which the pivot screw passes on the wrenn loco is above the trailing wheel axle while the hornbys one is below.As my fathers model is a three rail version I thought I'd google the Hornby 2 rail version but all these seem to follow the 3 rail pattern. Link to comment Share on other sites More sharing options...
Tony57 Posted August 7, 2023 Share Posted August 7, 2023 Hi 81FThe HD N2 has a vertical motor chassis block like the Duchess.Wrenn used a modified R1 chassis with a rear bogie attached with some small modification to the loco body.Thanks for the heads up on the bogie being different you may have saved me some cash.Give me a few days as I have ordered both HD couplings and coupling rivets so I will try to fit a HD coupling to my N2 without a rear coupling, the previous owner had cut off the plate that held the tension lock coupling in place so I would have to try and find a new rear bogie in any case. I will let you know how it went. Link to comment Share on other sites More sharing options...
Tony57 Posted August 14, 2023 Share Posted August 14, 2023 Hi 81FHave you sorted you issue with the N2 rear bogie?I have managed to fix a HD coupling to a N2 bogie, would you like me to describe what I used and did? Link to comment Share on other sites More sharing options...
81F Posted August 19, 2023 Author Share Posted August 19, 2023 I've ordered some bits, but I am a bit busy at the momenty so will probably not be able to look at things for a couple of weeks Link to comment Share on other sites More sharing options...
