Augustus Caesar Posted June 7, 2014 Share Posted June 7, 2014 Just so everyone knows... this forum, as some have already found, offers up a message that cutting and pasting cannot be done whilst the visitor uses Firefox. A popup message tells you so... However, open up a proggy like Word or a text editor, drag and drop your text from the thread into that editor. Then do the same in reverse. It works every time - obviously! There's always a way.... Link to comment Share on other sites More sharing options...
Muzza Posted June 9, 2014 Share Posted June 9, 2014 .....or you could simply try ctrl-v - the shortcut for paste. It works fine.I had the same trouble with the forum software at my college and found that ctl-v was the answer. The block below was pasted from your original post. I added the italic formatting. Just so everyone knows... this forum, as some have already found, offers up a message that cutting and pasting cannot be done whilst the visitor uses Firefox. A popup message tells you so... However, open up a proggy like Word or a text editor, drag and drop your text from the thread into that editor. Then do the same in reverse. It works every time - obviously! There's always a way.... Link to comment Share on other sites More sharing options...
Muzza Posted June 9, 2014 Share Posted June 9, 2014 Italic formatting that doesn't seem to work. Of course, I can't go back and edit............ Link to comment Share on other sites More sharing options...
Augustus Caesar Posted June 10, 2014 Author Share Posted June 10, 2014 Hi MuzzaThere are loads of ways to do the copy or drag and drop but I thought just showing one example would excite folk enough to try their favourite way.Of course, your example will help too... bar the italic bit as you state... :-) Link to comment Share on other sites More sharing options...
