colin_mitchell Posted March 30, 2015 Share Posted March 30, 2015 i am making a wartime theme rail layout. i want to have tanks on the lowloaders . i originally wanted the churchill tank but it is too large to fit. does anyone have a completed sherman and if so would it fit on my lowloader. the dimension is 6 cmsmany thanks Link to comment Share on other sites More sharing options...
paul_perkins Posted March 30, 2015 Share Posted March 30, 2015 hi been looking at the dimensions of the airfix kit of the sherman and its 3.4 cm wide so should be able to fit on the lowloaders Link to comment Share on other sites More sharing options...
Jon Murnaghan Posted March 31, 2015 Share Posted March 31, 2015 Hi Colin,The Churchill tank, like all British tanks, had to fit inside the railway loading guage but it was necessary to remove the air intake boxes from the sides to make it fit. They were only bolted in place for this reason. The Airfix Churchill is 4.7cm wide with the boxes but only 3.9cm without them. So the answer is to build the kit with the air intake boxes stowed on the engine cover.The Airfix Churchill is 1/76 scale which is the same as 00 scale. Most other kits will be in 1/72 which is a little larger.I like the Airfix Churchill even though (or maybe because of) all the tiny wheels and suspension arms. Here's one I converted into a Mk.VIII.../../../media/wysiwyg/Airfix/Forum/jon_murnaghan_tank.jpgJon Link to comment Share on other sites More sharing options...
Jon Murnaghan Posted March 31, 2015 Share Posted March 31, 2015 Ooh! My tank got squashed! :-)The original image is 800x600 pixels NOT square. But it looks like I can't edit it now.Jon Link to comment Share on other sites More sharing options...
Ratch Posted April 1, 2015 Share Posted April 1, 2015 All Airfix AFVs are 1/76 scale and compatible with 00 scale. Some have appeared in boxes saying they're 1/72 when in fact they're 1/76.See here...http://airfixtributeforum.myfastforum.org/viewtopic.php?f=71&t=1679 Link to comment Share on other sites More sharing options...
colin_mitchell Posted April 5, 2015 Author Share Posted April 5, 2015 hi jon. thanks for the advice and the photo! hope i can do a nice a job as that one! unfortunately my lowlaoder is only 3 cms wide, im making a hornby dublo 3 rail layout. i need to find perhaps a wider wagon or did the tank hang over each side a bit?regards colin Link to comment Share on other sites More sharing options...
Ratch Posted April 5, 2015 Share Posted April 5, 2015 Colin, you need to find out the loading gauge. This is the maximum width and height permissible on the railway.00 gauge = 4mm to the foot. Link to comment Share on other sites More sharing options...
