Blogs Posted July 4, 2015 Share Posted July 4, 2015 i need to put det cord decals on a Hawk canopy. Can I use decalfix without any effect to canopy Link to comment Share on other sites More sharing options...
DavidJC Posted July 5, 2015 Share Posted July 5, 2015 I don't know the Hawk canopy, but is it possible to try a bit on the inside of the canopy on a lower edge that might need painting on the outside? That way you get to test it, if it doesn't react well, hopefully then the outside edge paint might disguise it. Link to comment Share on other sites More sharing options...
Jonathan Mock Posted July 5, 2015 Share Posted July 5, 2015 I wouldn't use any setting solution, the clear plastic will be plenty smooth to suck the decal down with no air pockets. Link to comment Share on other sites More sharing options...
Blogs Posted July 5, 2015 Author Share Posted July 5, 2015 I wouldn't use any setting solution, the clear plastic will be plenty smooth to suck the decal down with no air pockets. Link to comment Share on other sites More sharing options...
