Adamico Posted October 28, 2015 Share Posted October 28, 2015 hi I have an old racing track Scalextric set 750 and i try to find raciing car. anyone can Help me andre Link to comment Share on other sites More sharing options...
Andy P. Posted October 29, 2015 Share Posted October 29, 2015 Hi Andre,Usually Scalextric part numbers start with a "C" or "P". I googled Scalextric 750 and didn't find any sets.The other problem is that there is a Spanish company called SCX that sometimes sells under the name Scalextric.In any case, if the track has two round pegs (sometimes called spoons) on either end it is either a Scalextric Classic or an SCX set. If it has one rounded tab and one square tab on either end it is the newer Scalextric Sport.Either type will be just between 15 and 16 cm wide.If it is not as wide it is a Scalectric Micro track.Any analog slot car, which is about 90% of what is being made will fit the track. So just find any car and put it on the track! Link to comment Share on other sites More sharing options...
Adamico Posted October 30, 2015 Author Share Posted October 30, 2015 HiThank for replyAll the track number start by PT and i found the racing car number: C.79 Is that help? Link to comment Share on other sites More sharing options...
Andy P. Posted October 30, 2015 Share Posted October 30, 2015 To be honest Andre I don't know what your question is.I also speak German and French and I can decipher Spanish if English is not your first language.Maybe you can explain more clearly what you are trying to do?As I said, any car should work on the track. Link to comment Share on other sites More sharing options...
