Bjd Posted December 9, 2015 Share Posted December 9, 2015 I have just bought a Micro Hyper car set fot my 7 and 5 year old grandsons for Christmas and Ihave been ensuring that it works OK - as you do!! The controllers seem to come with the setting in the reduced speed position with the dots on the screw head and controller body aligned. I would like to know how I set to full power - do I turn the slotted screw head clockwise or antii clockwise and how far. I don't want to experiment as it would be sad if i broke it before Christmas Day. You see I can play now but on christmas day I wont get a look in! Incidentally Ihave a lot more space than they have at home so should I buy a full size set to 'practice on so that they don't beat me when i visit them!!!!? Hope to hear from someone pleaeBernard Link to comment Share on other sites More sharing options...
Andy P. Posted December 10, 2015 Share Posted December 10, 2015 Hi Bernard,I had the same problem when I got an ARC ONE set:https://slotcarp.wordpress.com/#SetupThe "dot to dot" setting is the lowest i.e. slowest setting and moving the screw counterclockwise i.e. away from the dot increases the speed.Make sure you use a flathead screwdrivers or dull knife that fits the slit well otherwise the plastic will get scratched and not looks as nice.Alternatively, you can use a wall mounted (sometimes called socket mounted) dimmer and plug the power adapter into that. I personally find it less fiddely this way. You leave the controllers at full throttle and gently increase speed using the dimmer dial until the car fly off. Back it off a notch and you are good to go.Personally I think if you have the space you should go for a SPORT set up. Micro is limited to the smaller "H0" care but you can race everything on SPORT (except big 1/24 cars). There are no wall crawling curves or loop-the-loops but there is a flying leap and cross over sections.I only see Micro an advantage if you don't have the space and/or you love the motif of the prodcuts (Cars, Toy Story, Star Wars etc). You can theoretically race Micro cars on Sport ;-)Good luck! Link to comment Share on other sites More sharing options...
richard_tilwick Posted November 13, 2016 Share Posted November 13, 2016 coming to you from across the pond. Using the dimmer is a great idea Andy. Will that shorten the life of motoers and controllers? Would it work on digital sets? As an aside, does Scalextric make a plug that will allow the digital converter units to be transferred to different cars? I have over fifty cars and it could get expensive to have to buy a digital module for each car.thank you.. Link to comment Share on other sites More sharing options...
Andy P. Posted November 14, 2016 Share Posted November 14, 2016 Howdy from Europe ...The dimmer can possibly cause the power packs to warm up but I used it for over 4 hours non-stop without a problem. Do test it and keep an eye on it though.I doubt it will work with digital, as it is more sensitive to current. I don't drive digital so I don't know.Many of the Hornby Scalextric cars ard DPR=Digital Plug Ready which means you can swap the chip across cars no problem.If the car is not Hornby Scalextric or Slot.IT you have to use a chip that is soldered and therefore not tranferrable. Link to comment Share on other sites More sharing options...
DougieD Posted January 11, 2020 Share Posted January 11, 2020 Just got one of the newer 9v cars (Wile E Coyote), and tried it out on my "old" 19v track. It seems to work great, but I am concerned about putting the higher voltage through it. What is the voltage of the controller when it's in the dots-aligned position? (From the Hypercars set.) I'm thinking maybe I could just run the 9v cars on my old-style track with the limiter on. I didn't know the voltage setting was a continuum from high to low; I thought it was a switch - high or low, with nothing in-between. What would be the best setting to use, then?Thanks for any advice. Link to comment Share on other sites More sharing options...
woodcote Posted January 11, 2020 Share Posted January 11, 2020 Hi DougieD - the new cars will run (pretty quickly!) at 19v. At the full 19 volts, the motors may start to fail after a while, so your idea of using the speed limiting switch on the controller is a good one. The switch limits how far the wiper will travel up the resistor on the controller and will probably give you 9-10 volts maximum on the lower setting of the two-position controllers. The newer four-position controllers offer 25%, 50%, 75% and 100% - so 50% would be the ideal setting for those. I hope that answers you questions. Link to comment Share on other sites More sharing options...
DougieD Posted January 11, 2020 Share Posted January 11, 2020 Hi DougieD - the new cars will run (pretty quickly!) at 19v. At the full 19 volts, the motors may start to fail after a while, so your idea of using the speed limiting switch on the controller is a good one. The switch limits how far the wiper will travel up the resistor on the controller and will probably give you 9-10 volts maximum on the lower setting of the two-position controllers. The newer four-position controllers offer 25%, 50%, 75% and 100% - so 50% would be the ideal setting for those. I hope that answers you questions. It does. Thanks! Link to comment Share on other sites More sharing options...
