David55 Posted October 31, 2011 Share Posted October 31, 2011 I have a 4-6-0 that stops on one peculiar set up, this is two points followed directly by a crossover. At either side I have a power link and each point is permanently wired.The train will go over at full speed, but one notch down it stops and starts up again.It goes over all the other points with no problem.Is there a simple solution to this?Thanks for everyones help. Link to comment Share on other sites More sharing options...
Flashbang Posted October 31, 2011 Share Posted October 31, 2011 HiThe real answer is to replace the points and local track work with Electro frog points.Using Insulated frog points will quite often cause slow speed stalling problems.However, initially ensure all the wheel treads of the loco are spotlessly clean. Then clean the point rails including the moving switch blades too. I recommend you use Isopropyl Alcohol (IPA) 99% type applied via a lint free cloth on both wheel treads and the rail tops. Alternatively use a Peco Pl40 powered wheel cleaning set on the loco and a track rubber on the rails.Check and clean the inside faces of the points fixed stock rail and the open moving switch rail where they touch together when closed. Clean both sides of the point.Next, ensure the points are laid flat. Both along and across the point. I use a 12" steel rule on edge placed along the point rails, then I get down low so as my eye is as near as possible to the rail level. By looking along the rules edge and rail top and then you can see any daylight where the point isn't flat. Use pieces of card as packing to raise the point as required.You already have rail power feeds at the points, so this should help considerably. Link to comment Share on other sites More sharing options...
Southernman777 Posted November 1, 2011 Share Posted November 1, 2011 David 55,Hi. I had this problem with some of my longer steam locos on 'dead frogs' turnouts. It seems the pick up wheels create a short circuit as they go over the crossover and touch the turnout blades at the same time. If you draw it out on paper you will see what is happening.The solution, for me, was to change the electrical switching on the offending points (both curved turnouts) so the point blade not being run over is dead. Hence no short can happen as the long steam engines & others pass by. This method fully works and stops the problem. On my layout this was an issue only with some turnouts and only with long steam engines. I have long diesel engines and multi units with power pick-ups both ends and it was & is not a problem. Might be the way long tender engines run?I hope this helps you. Link to comment Share on other sites More sharing options...
Flashbang Posted November 1, 2011 Share Posted November 1, 2011 Southernman777 said:David 55,Hi. I had this problem with some of my longer steam locos on 'dead frogs' turnouts. It seems the pick up wheels create a short circuit as they go over the crossover and touch the turnout blades at the same time. If you draw it out on paper you will see what is happening. HiFrom the initial description given by the OP (David 55) his problem isn't shorting, but stopping and then going off again. If its a short circuit the console should detect this and show this up as an error. But there is no mention of this?However, if it is a short circuit, then your answer re having the open points switch blade isolated is the answer. The open point blade can be made electrically dead when open by fitting Insulated Rail Joiners onto the point ends Vee rails.However the real fix is to check and adjust the problem locos wheel Back to Back setting. Which on "OO" should be 14.4mm +/-0.05mm. A B2B gauge is ideal for this and such gauges can be obtained from all good model shops or direct from The Double O Gauge Association - Buying their 'Universal B2B gauge'. http://www.doubleogauge.com/shop.htm Link to comment Share on other sites More sharing options...
walkingthedog Posted November 1, 2011 Share Posted November 1, 2011 I have two crossovers (diamond crossings) and some of my loco stutter as they cross them. They have rather a lot of plastic at the crossing points and at some speeds this tends to slightly lift the loco wheels causing them to stop/start. Make sure they are absolutely flat, add extra trackpins if needed. Link to comment Share on other sites More sharing options...
David55 Posted November 1, 2011 Author Share Posted November 1, 2011 walkingthedog said:I have two crossovers (diamond crossings) and some of my loco stutter as they cross them. They have rather a lot of plastic at the crossing points and at some speeds this tends to slightly lift the loco wheels causing them to stop/start. Make sure they are absolutely flat, add extra trackpins if needed. Link to comment Share on other sites More sharing options...
David55 Posted November 1, 2011 Author Share Posted November 1, 2011 Thanls for all of your replies.I have checked the levels and they do need adjusting, some badly.I will adjust these and purchase a B2B gauge as suggested.It's not a short, otherwise everything would stop running.I have always fancied a class 08, but sent it back for the same problem. Maybe this is why. Link to comment Share on other sites More sharing options...
walkingthedog Posted November 1, 2011 Share Posted November 1, 2011 Points and especially diamond crossing must be absolutely flat. Link to comment Share on other sites More sharing options...
David55 Posted November 1, 2011 Author Share Posted November 1, 2011 walkingthedog said:Points and especially diamond crossing must be absolutely flat. Link to comment Share on other sites More sharing options...
David55 Posted November 1, 2011 Author Share Posted November 1, 2011 I have levelled the points that were the problem and the train runs over them at shunt speed with no stopping.I'll now check all the others.Even my diesels have stopped squeaking.Never thought i'd find a use for a extension pack b box Link to comment Share on other sites More sharing options...
Southernman777 Posted November 1, 2011 Share Posted November 1, 2011 Great, have fun. Link to comment Share on other sites More sharing options...
Blackbird Posted November 2, 2011 Share Posted November 2, 2011 Hi David,Hornby isolating points have a dead (isolated) position over the plastic frog, but as all locos have multiple pick up wheels they will span the dead spot. I would recommend checking, and cleaning the pickup wipers on the loco also cleaning the treads on the loco wheels. Also ensuring the track is flat so the all of the wheels are making contact. Link to comment Share on other sites More sharing options...
David55 Posted November 3, 2011 Author Share Posted November 3, 2011 Blackbird said:Hi David,Hornby isolating points have a dead (isolated) position over the plastic frog, but as all locos have multiple pick up wheels they will span the dead spot. I would recommend checking, and cleaning the pickup wipers on the loco also cleaning the treads on the loco wheels. Also ensuring the track is flat so the all of the wheels are making contact. Link to comment Share on other sites More sharing options...
David55 Posted November 3, 2011 Author Share Posted November 3, 2011 I've now been through all the points and cleaned the track.I have looked at cleaning the wheels but dont know how to turn them and where do I find the pick up wipers on the locos. I run class 20, 37, 40, 42, 43, 47,50 and 55 as well as two dmu's. Will these be in the same place? Link to comment Share on other sites More sharing options...
David55 Posted November 3, 2011 Author Share Posted November 3, 2011 David55 said:I've now been through all the points and cleaned the track.I have looked at cleaning the wheels but dont know how to turn them and where do I find the pick up wipers on the locos. I run class 20, 37, 40, 42, 43, 47,50 and 55 as well as two dmu's. Will these be in the same place? Link to comment Share on other sites More sharing options...
David55 Posted November 3, 2011 Author Share Posted November 3, 2011 there is a thread on general discussion named 3 questions which asks the same. can we post all replies to this.Thanks to all Link to comment Share on other sites More sharing options...
Doodle009 Posted November 8, 2011 Share Posted November 8, 2011 Check your back to back wheel distances on your locos. I had this problem and this was what it was,the loco wheels were causing short outs on the points.Don't replace your track until you've tried this as it is expensive and in a lot of cases unnecessary! A back to back gauge is only a fiver,the best fiver I ever spent,cured all my loco problems over points.Andy Link to comment Share on other sites More sharing options...
