Bren Posted November 10, 2011 Share Posted November 10, 2011 hiya,just trying to get to grips with DCC and I'm confused about the need for a DCC Bus!From reading up it seems theres 2 ways to go:1) Either connect your wires from the controller direct to the track and the rails carry the current to make all the track live.OR2)Buy 2 suitable length cables wires, attach them to the controller and feed underneath the track in a ring pattern. Then solder dropper wires from this ring Bus to the tracks every 3feet or so.As a newby to DCC the first option seems so much easier. My question is what are the benefits of option 2 when option 1 is easier and does the same thing.Thanks for your help.B Link to comment Share on other sites More sharing options...
Gregd99 Posted November 11, 2011 Share Posted November 11, 2011 2) has many advantages. there are multiple connection points to the track so that your layout is less susceptible to poor fish plate connections. there is less voltage drop around the layout due to heavier gauge wires running under the tracks. there is less dependence on point clips.BUT....my layout has been running with just a single connection for 2-3 years. the track is relatively short (20m/66'). My intention is not to run a bus per se but to have a star with multiple layout connections.while everything is working fine a more sophisticated solution stays lower on my priority list. Link to comment Share on other sites More sharing options...
Southernman777 Posted November 11, 2011 Share Posted November 11, 2011 Bren,Hi, my current OO layout does not use 'BUS' cables but it's an experiment using both DC & DCC control on different tracks. My next DCC one will use 'BUS' cables.The BUS cables are more to ensure the DCC control signals are not lost with poor fish-plate or track connections. On larger layouts such arrangements are usually required. On smaller layouts either method should work.My OO layout size is 16 foot by 4 foot. On the DC circuits I have two power feeds. On the DCC circuits I have four power feeds to ensure the trains run fine.I hope this helps you. Have fun, Link to comment Share on other sites More sharing options...
Bren Posted November 13, 2011 Author Share Posted November 13, 2011 Thanks for the information and advice.Bren Link to comment Share on other sites More sharing options...
FinnerZ Posted November 13, 2011 Share Posted November 13, 2011 My layout is entirely DCC and although it is 12' by 4', it is built on two tables (connected by a removable cable) and a lot of the track is quite old so I have added a DCC bus using mains size wire connected to panel pins which are then soldered to a bit of fuse wire that connects to the rails and many places around the layout. This is also good because it means if you get a reverse loop module or accessory decoders, they can be given a strong connection to the bus rather than a poor connection to the track. Link to comment Share on other sites More sharing options...
Blackbird Posted November 15, 2011 Share Posted November 15, 2011 As you will see from previous comments, a DCC 'bus' is not always necessary. If you construct your lay out with a simple feed, and it works to your satisfaction, then OK. The DCC bus system will overcome prospective problems of power feed and DCC signal interpretation , on larger, complex layouts. However, a basic layout depending on track connectors (fishplates) may develop problems in time, a hard wired busmain is unlikely to. Link to comment Share on other sites More sharing options...
