Allistair1964 Posted November 19, 2011 Share Posted November 19, 2011 Hi AllI am converting all my Sons loco's to DCC when converting a standard 0-4-0 a capacitors broke so today I phoned my local model shop to be told that you don't need these capacitors for DCC is this correct?ThanksAllistair1964 Link to comment Share on other sites More sharing options...
poliss Posted November 19, 2011 Share Posted November 19, 2011 Yes. Indeed most guides tell you to remove the capacitors. Link to comment Share on other sites More sharing options...
FinnerZ Posted November 19, 2011 Share Posted November 19, 2011 Would you recomend removing them on trains that I've already converted to DCC? Link to comment Share on other sites More sharing options...
Blackbird Posted November 20, 2011 Share Posted November 20, 2011 If your DCC loco runs without problems, then leave it as it is. The capacitors are fitted to the motor to reduce RF interferance from commutator/brush arcing. This can, theoretically, interfere with the back emf referance to the decoder, that is why, if you have problems, it is recomended to remove them. The capacitors fitted to the track supplies (for the same reason, RF suppression) should be removed as they can interfere with the DCC signals to the loco.Basicaly, a capacitor will conduct an AC current (the high frequency DCC signal) an in effect short it, the supply to the loco. But the feed from the decoder to the motor has no DCC signal and will have no effect on the input signal. Link to comment Share on other sites More sharing options...
Allistair1964 Posted November 20, 2011 Author Share Posted November 20, 2011 Hi All This was my first post on the fourms thanks for all the helpRgds Link to comment Share on other sites More sharing options...
rft_hillview Posted December 7, 2011 Share Posted December 7, 2011 Hi AllI am a Grandpa getting ready for a DCC conversion present on my Grandson's layout.Having successfully converted R2960 - a small 0-4-0 chassis - I started to convert R2375 Virgin Shunter. It soon became apparent that the electrics are different.The Virgin shunter has only one capacitor in parallel with the motor and the pickup connections to the wheels are made by simply placing the motor so that the tags on the motor where the capacitor is connected rest on copper strips from the wheel pickups.The capacitor, which in the Hornby standard DCC instructions for 0-4-0 is in series with one motor feed, is not part of the Virgin Shunter.Does anyone know if it can simply be ignored for DCC conversion.If not then does anyone know what value the capacitor is. It is not the small bit of toffee capacitor but the in line tubular one (the red one in the Hornby online instructions) which is missing.many thanksRalph Link to comment Share on other sites More sharing options...
Rog RJ Posted December 7, 2011 Share Posted December 7, 2011 Don't worry about it. It's not needed for DCC. Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 8, 2011 Share Posted December 8, 2011 Nope but it is needed to cure RF problems and could cause tv interferance to neighbours TV's which is illegal. Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 8, 2011 Share Posted December 8, 2011 Removing the capacitor/s can stop reduction or prevention of RF interferance. It's highly unlikely of course but the RF supression should be there. Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 8, 2011 Share Posted December 8, 2011 Your local shop shouldn't have offered the advice Allistair1964 without explaing why the capacitor/s are there and what they do. Link to comment Share on other sites More sharing options...
poliss Posted December 8, 2011 Share Posted December 8, 2011 It all depends on the decoder. Some have built in suppression circuitry so it will be quite ok to remove the capacitors. Link to comment Share on other sites More sharing options...
Flashbang Posted December 8, 2011 Share Posted December 8, 2011 RF Capacitors fitted internally in locos.Theory first - The decoder uses Pulse Width Modulation (PWM) to control how the motor speed is set and the decoder's control circuit tries to measure the back-emf from the motor during the gaps in these pulses. This allows the decoder to adjust its output in response to these measurements . Acting like a mini Cruse Control. Trying to maintain as much as possible the motors speed to that required, regardless on whether the motor is loaded or running lighter – The loco is on the flat, pulling up hill or running down a gradient.A RF capacitor tries to prevent high frequency - radio frequency (RF) noise, being sent back onto the rails from the arcing occurring at the motors commutator to brush connection. Where a DCC decoder is fitted the voltage and current coming back from the motor will be modified by the capacitor. The overall effect is that the decoder cannot accurately sense the back-emf, so motor control can become poor.The decoder will be doing this work at quite high frequencies – typically 20,000Hz (20kHz) and some makes are doing this at even higher frequencies. RF Capacitors, are normally little flattish round two wire devices, often a yellowish orange or brownish colour, but they can be of any shape and any colour. They are normally connected across the motor brushes, many directly onto the motors wiring tags as often the brushes are encased is a sealed metal ‘Can’. Some capacitors are not always close to the motor, they could be fitted onto the locos main circuit board. Be careful in identifying them when your going to remove them, there can be capacitors in locos used to help stop the flickering of lights. On some DCC powered locos larger sized capacitors are mainly used to keep the motor running for a second when rail to wheel contact is lost. So called ‘UPS’ or ‘Stay Alive’ capacitors.With dc (analogue) the motors RF interference is initially suppressed by the motor capacitors, but as the motor is directly connected to the rails the RF signals from both the motor and any arcing between rails and wheels is passed easily along the rails which act like large aerials and transmit the RF interference even better! This is why RF suppression capacitor are fitted into dc power clips/power track sections in an attempt to further reduce the RF interference. With DCC, the motor is not directly connected to the rails. The rail power is converted into PWM via the motor control device on the decoders circuit board. RF signals will in the main stop at the decoder. However, dirty rails and dirty pick-up wheel treads will cause arcing and this will transmit RF interference! This is not stopped by anything on a DCC layout as no power clip etc capacitors are to be used!Much of the RF interference issues are IMO overstated - they are required under EU / CE manufacturing laws, so the manufacturer has to comply with the regulation, but in practise they often make little or no real difference. Many ‘up market’ DCC decoder manufactures will request the locos owner or decoder installer remove all loco suppression capacitors while wiring or installing the decoder. Cheaper budget priced decoders, which do not have such sophisticated motor control circuits built into the decoder will often will work happily with the suppression capacitors still fitted. My advice is, always has been and will remain so… If the loco runs correctly throughout its entire speed range, then leave the capacitors alone. However, if the loco exhibits poor running – typically surging at certain speed steps, then remove all the RF suppression capacitors.I've never heard of a RF detector vans staff coming round to arrest you! Even if they did call on you, they offer help not prosecution, unless you have been visited by them previously and not carried out their recommendations! The local fast food delivery companies motorbike or someone using an old mains electric drill will probably be putting out vastly more RF interference! Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 10, 2011 Share Posted December 10, 2011 I agree Flashbang leave the capcitors where they are, unless they give trouble, making sure the decoder has suppression built in. Detector equipment does exist, and has been used many times in the past to investigate a complaint, usually as you say advice is offered in the first instance, but a repeat offender can find themselves with a hefty bill.To be on the safe side leave those capacitors where they are, unless they give trouble or the decoder has built in suppression. Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 10, 2011 Share Posted December 10, 2011 Shops shouldn't advise to just remove the capacitor/s without checking to see if the owner's decoder has built in RF supression. Link to comment Share on other sites More sharing options...
