stevecamden Posted November 24, 2011 Share Posted November 24, 2011 HiThis is a strange one and may be related to things already documented in here as bugs between the PC and elite.I have a Bachmann 411 which runs fine through the Elite. When assigned in Railmaster it works for a while and then I can't get it to move, even though other functions work OK ( lights, horn etc). Resetting the CV8 to factory settings doesn't help. The only thing I can do to get it going again either through RM or the Elite ( now) is to assign a new loco id that it has NOT had before. ( this I find really bizarre).So, re-assigned new loco-id - works for a bit then stops ( under RM) As I said no problems if it is used on the Elite.I wondered if some of the functions could effect the throttle and loco id? Is this possible? And why can't you re-programme it back with the original loco id?Any ideas anyone as I will just have to have it not operated through RM. BTW - My other three loco's run fine through RM.Steve Link to comment Share on other sites More sharing options...
stevecamden Posted December 2, 2011 Author Share Posted December 2, 2011 I sorted this by re-setting the Elite. The post got blocked by Hornby as they thought it unsuitable for some reason. Link to comment Share on other sites More sharing options...
