Rogueraven Posted November 29, 2016 Share Posted November 29, 2016 /media/tinymce_upload/df7e54a16b83f5d7d096460ecb5c1233.JPGYoutube https://youtu.be/QvPBkvkYYRgSo once assembled I painted with Humbrol 113 (Rust) enamel, 2 thin coats and sealed with Humbrol clear Matt varnish. I then used soft pastels (Earth colors) to make the rust color more authentic, sealed again with a thin Humbrol Matt varnish and allowing around 30 hours dry time. I used Humbrol Maskol to mark up potential rust spots allowing to dry before carefully applying Humbrol 117 Acrylic (green) which I allowed to dry before removing Maskol. I then used Humbrol dark green wash to darken some areas before applying a thin coat of Humbrol clear gloss varnish. After applying decals with decal softener I applied a thin coat of Matt varnish to only the decals to seal them. I then applied some dark grey wash and some dark brown wash to simulate water run off and highlighted with 117 Acrylic (Green). Allowing lots of dry time I think mixed some soft pastels to give the dirty dusty look and sealed with a thin coat of Matt varnish.I hope every likes I am happy with it :) Link to comment Share on other sites More sharing options...
