rg127rz Posted June 14, 2011 Share Posted June 14, 2011 I have 2 Select units that I want to connect together but keep reading about Walkabout units. Are these different from the normal Select units and do I need a 4amp power supply to run 2 units if I can connect them together.Russ Link to comment Share on other sites More sharing options...
poliss Posted June 14, 2011 Share Posted June 14, 2011 You connect the Select's together with the R8266 lead. The 4amp power supply will enable you to run more locos, but two Select's will work without one. See your manual for full instructions.The second Select will get it's power from the first one. You must never use two mains power supply packs. Link to comment Share on other sites More sharing options...
rg127rz Posted June 14, 2011 Author Share Posted June 14, 2011 Thanks Poliss I have ordered the lead and will try it out as soon as it comesRuss Link to comment Share on other sites More sharing options...
