MPW Posted February 4, 2017 Share Posted February 4, 2017 Grateful for advice on how to remove bodyshell from class 156 so I can fit the DCC chip. The 'operating and maintenance instructions' only say 'unclip body from sides and ease off by lifting upwards'. Has anyone achieved this on this model and can share the secret of the unclipping part?In case it's relevant, I have the 'DCC-Ready' R2695, which runs ok on DC but now needs to enter the digital age...Many thanks in advance for any help. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 4, 2017 Share Posted February 4, 2017 Typically when instructions say 'unclip' along the body sides. The use of some thin plasti-card or an old plastic Bank card cut into strips and slipped between the body and chassis, holds the clips apart to aid body removal../media/tinymce_upload/d190d0f7a4765e38124f7cf435042419.jpg.Double check to make sure that there are no hidden screws in the chassis underside that are used to secure the interior moulding aka seating. Loosening these screws (if present) can, on some models, provide more slack between the body and chassis. Link to comment Share on other sites More sharing options...
MPW Posted February 4, 2017 Author Share Posted February 4, 2017 Chris,Thanks for your quick and very helpful reply. With the help of a thin screwdriver and a slice of such card, all is now very well. I've ordered the decoder and look forward to having this model going DCC very soon.Cheers PS interesting that the destination blinds say Norwich on this Scotrail unit. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 4, 2017 Share Posted February 4, 2017 Glad to have been of service. Just out of curiosity, were there any hidden screws on the underside? Link to comment Share on other sites More sharing options...
MPW Posted February 4, 2017 Author Share Posted February 4, 2017 No screws, just a few clips / lugs on each side. Cheers Link to comment Share on other sites More sharing options...
Chrissaf Posted February 4, 2017 Share Posted February 4, 2017 TA - thanks for the clarification. Additional info may help others reading this topic at a later date. Link to comment Share on other sites More sharing options...
Michael Tanguy Posted March 23, 2018 Share Posted March 23, 2018 Hello, following on from the above thread, can anyone give some some advice please on the best way to fit a Hornby R8249 decoder into these models? it's a tight fit and I don't want to block the motor in any way.Any ideas much appreciated. Thank you Link to comment Share on other sites More sharing options...
96RAF Posted March 23, 2018 Share Posted March 23, 2018 Making sure it is insulated secure the decoder on top of the weights amidships using double sided sticky pad or blue tack.See service sheet 303.Rob Link to comment Share on other sites More sharing options...
Michael Tanguy Posted March 24, 2018 Share Posted March 24, 2018 Hi Rob,Many thanks for your suggestion. I will try it on my model.Michael Link to comment Share on other sites More sharing options...
Waylander101 Posted October 11, 2019 Share Posted October 11, 2019 For this model I suggest you don't remove the entire bodyshell; jus the roof is enough to give access to the DCC socket Link to comment Share on other sites More sharing options...
96RAF Posted October 11, 2019 Share Posted October 11, 2019 For this model I suggest you don't remove the entire bodyshell; jus the roof is enough to give access to the DCC socket I thought there was another thread on here where the answer to ‘how do I remove the body’ was ‘you don’t, just the roof’.As usual the forum search engine fails to find it. Link to comment Share on other sites More sharing options...
colin142 Posted October 16, 2019 Share Posted October 16, 2019 I recently bought the new Hornby 156 Northern RAF, and had trouble removing the bodyshell. In the end I found it easier to remove the roof and prise the body retaining lugs at each end with a small screwdriver.The boby lifted off with ease. Link to comment Share on other sites More sharing options...
