Chris-K Posted April 13, 2017 Share Posted April 13, 2017 Hi, Does anyone know if there are any updates for Track-Master, I've installed it and running Version 1.04 at the minute Thanks for any help on this Link to comment Share on other sites More sharing options...
Chrissaf Posted April 13, 2017 Share Posted April 13, 2017 I can't tell you if 1.04 is the latest version or not, but the latest version can be downloaded from herehttp://www.powerpos.com/track-master/tm_setup.exeDownload it, run the file to over-install current version and then check to see if same or later than 1.04.Chances are that 1.04 may be the latest version, because even if you installed yours from an earlier CD, the installer should (one would expect) perform an online check for a later version. This online check, is only applicable when installing 'Trackmaster' for the very first time. The online check doesn't occur when just doing an over-install update..For the benefit of others. It would be really helpful if you could come back here and confirm whether 1.04 is the latest version of not, once you have followed the suggestion above. Link to comment Share on other sites More sharing options...
Chris-K Posted April 13, 2017 Author Share Posted April 13, 2017 Thanks Alot for The Reply After Downloading the link you gave me that was 1.09 so that was an updated version :) Link to comment Share on other sites More sharing options...
Rail Moose Posted April 22, 2017 Share Posted April 22, 2017 Has anyone successfully set up Track-Master on Windows 10 Please? Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 23, 2017 Share Posted April 23, 2017 Moose, not a good idea to add to the end of a solved problem that isn't your own issue, you may not attract the people you need to answer your question. Do do you actually have a problem installing on W10 or anticipating you might. I'd just try installing the latest from Chris 's link above then run as administrator and see how you go. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 23, 2017 Share Posted April 23, 2017 There is no reason why it shouldn't run on Windows 10, but the product is obsolete. If you are not in possession of a valid activation key, then you can only install it in 'Evaluation Mode'. So what would be the point of doing that..If the intention was to use Hornby TrackMaster to plan a Hornby layout. Then download, install and use SCARM (Simple Computer Aided Railway Modelling). SCARM (click the preceding URL link) is completely free and used by many forum contributors. Link to comment Share on other sites More sharing options...
96RAF Posted April 23, 2017 Share Posted April 23, 2017 SCARM in addition to being a very good track planner also has a 3-D view and you can operate your train on your track using the simulator as well. Link to comment Share on other sites More sharing options...
